Gauge cluster problem please help!!
I recently swapped my stock cluster for a jdm Si. Everything works fine except for the "door open" indicator which is located under the tach, and also the "seatbelt light" and "low fuel" warning don't work. I am not 100% sure on the low fuel, but I would hate to run out of fuel because I wanted to test the light. Any input is greatly appreciated.
Location: Why so you can pretend like youre interested, FL/OK
Re: Gauge cluster problem please help!! (c_buz)
Pretty messed up that I attempted to help you out, but to do so I had to look through your history of topics and watched list.
Make it easier for anyone attempting to help and list the information from which vehicle to which. Mentioning what the cluster is from helps as well. I have never heard of a JDM SI.
Re: Gauge cluster problem please help!! (INVALID)
Sorry about that. My car is a 1994 CX hatch that came without a tach. I was told that the JDM cluster was from an SI. Anyways, The Jdm cluster has white face gauges and orange numbers. I have seen it in this website before but can't find any pics of it.
The seatbelt light should be working, but the low fuel and the door indicators will not. the 1992-95 Honda Civics were not available with either option.
Electrician
Indeed, 1st, check the bulbs. many times these clusters come with blown bulbs, that might be the case. BTW, if your 2-wire harness that connects to your seatbelt harness connected. I forgot mine disconnected and it didn't come on. Reconnected it, viola!
BlueIntegraBoy
16
12-19-2004 10:27 PM
naya1civic
06-13-2004 03:59 PM
