t3/t4 B good for 350whp??
Old Jun 21, 2004 | 09:37 AM
graphic's Avatar
Default t3/t4 B good for 350whp??
i have this POS turbonetics turbo
t3/t4 h-3 compressor wheel .63 a/r , stage 3 exhaust
it is supposed to flow 49lb/min
i will be running her at 18psi stock head/ built bottom end h22
750cc injectors and tuned w/ the AEM ems
think 400whp is possible???
Old Jun 21, 2004 | 09:39 AM
ELSpool's Avatar
This is H-T, anything is possible.
Old Jun 21, 2004 | 09:42 AM
Mad Cow's Avatar
Default Re: t3/t4 B good for 350whp?? (graphic)
You should be able to do it.
I personally would go for a turbo that's a biut bigger, say something that will make 400hp, and turn the boost down a bit. People always seem to run into problems with not making as much power as they like when they are getting up near the max efficiency of their turbo... just my prefrence I guess.
Old Jun 21, 2004 | 01:10 PM
graphic's Avatar
Default Re: t3/t4 B good for 350whp?? (Mad Cow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mad Cow &raquo;</TD></TR><TR><TD CLASS="quote">You should be able to do it.
I personally would go for a turbo that's a biut bigger, say something that will make 400hp, and turn the boost down a bit. People always seem to run into problems with not making as much power as they like when they are getting up near the max efficiency of their turbo... just my prefrence I guess.</TD></TR></TABLE>
you think 18 psi is near the max efficiency of the h-3 compressor wheel???
hondaaccord94
Dec 2, 2005 07:22 AM
oemDC2
Nov 25, 2003 03:44 AM
Andre
Jul 4, 2003 06:07 PM
95lsteg
Mar 26, 2003 05:14 PM
