Average temp of a header during operation ?
Old Jun 21, 2004 | 07:34 AM
X2BOARD's Avatar
Default Average temp of a header during operation ?
Just as it says...
Just want to know what the normal surface temperature of a stock or aftermarket header on a B series would get to if anyone has something to measure it.
Old Jun 21, 2004 | 08:08 AM
dfoxengr's Avatar
Default Re: Average temp of a header during operation ? (X2BOARD)
800-900 F
Old Jun 21, 2004 | 08:34 AM
GZERO's Avatar
can i ask what are you planing?
Old Jun 21, 2004 | 08:58 AM
Ekasey's Avatar
Default Re: Average temp of a header during operation ? (GZERO)
Are you talking baout under load? What part of the Header ? what RPM ? Ceramic coated mild steel or Stainless?
Old Jun 21, 2004 | 10:41 AM
X2BOARD's Avatar
Default Re: Average temp of a header during operation ? (eLusive ek4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eLusive ek4 &raquo;</TD></TR><TR><TD CLASS="quote">Are you talking baout under load? What part of the Header ? what RPM ? Ceramic coated mild steel or Stainless?</TD></TR></TABLE>
A temp range would be fine....Avg temp to Max temp.... I said either stock or aftermarket.
I am just looking around at powdercoatings and thermal coatings. I have access to the machine/oven to apply them. At 800+ deg F... I guess I can throw my powdercoats out the window.
Old Jun 21, 2004 | 10:46 AM
Ekasey's Avatar
Yeah a safe rang ewould be from 1100 to 1500 F
Old Jun 22, 2004 | 07:33 AM
X2BOARD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eLusive ek4 &raquo;</TD></TR><TR><TD CLASS="quote">Yeah a safe rang ewould be from 1100 to 1500 F </TD></TR></TABLE>
that's what I'm talkin' bout.... thanks. (damn that's high)
Old Jun 22, 2004 | 11:09 AM
dfoxengr's Avatar
thats too high turbo gets to only 1600 of so.
Old Jun 22, 2004 | 11:26 AM
Ekasey's Avatar
Default Re: Average temp of a header during operation ? (hybridvteceg)
he asked for a rnage usually when people ask for rnage you give them a fairly high range. reason being better safe then sorry
Old Jun 22, 2004 | 11:39 AM
X2BOARD's Avatar
where does the all motor header get to then ?
Old Jun 22, 2004 | 11:47 AM
dfoxengr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by X2BOARD &raquo;</TD></TR><TR><TD CLASS="quote">where does the all motor header get to then ?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg &raquo;</TD></TR><TR><TD CLASS="quote">800-900 F</TD></TR></TABLE>
the first post on the thread
Old Jun 22, 2004 | 12:26 PM
Ekasey's Avatar
under race conditions the average temp of the haader will be around 1100 degrees. We wouldn't know that though we only build headers and sell the components for a living
Old Jun 22, 2004 | 03:55 PM
ion_four's Avatar
I would think that the temps would be slightly higher, like ~1300ºF when cruising, or under load for a long time. I am basing this on my experience with turbo cars, when cruising out of boost. I can't say for certain, though, since I've only used EGT gauges on turbo cars.
Old Jun 22, 2004 | 04:13 PM
Ekasey's Avatar
Default Re: Average temp of a header during operation ? (ion_four)
you would be correct in this instance i believe we are talking about an NA car but that is why i have a wide range of<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eLusive ek4 &raquo;</TD></TR><TR><TD CLASS="quote">Yeah a safe range would be from 1100 to 1500 F </TD></TR></TABLE>
for my first post ^_^ kind of covering all bases since the creator wasn't that sepcific
flight50
Mar 31, 2008 09:35 AM
Capo dei Capi
Dec 6, 2007 08:06 PM
kornerk12
May 26, 2007 10:10 AM
itr1244
Welding / Fabrication
Sep 4, 2006 09:04 PM
darkspector2.0
Aug 19, 2006 08:07 PM
