Need help Installing Passengerside Front Hard Brake Line
Old Jun 20, 2004 | 10:23 PM
MugenB16A2's Avatar
Default Need help Installing Passengerside Front Hard Brake Line
I installed a set of Goodridge SS brake lines, and I made the mistake of using a standard (Not standard as in 5/16", but Normal style ended) wrenches rather than Flare Ended wrenches. Long story short I ended up rounding out the end of the Hard line that screws into the new Soft (SS) barke line....
I purchased a NEW hardline from my local Honda shop and I was wondering... How hard is it to "Shimmy" the Hard line into place while having the motor in, and pretty much everything there. We're talking about from the Proportioning Valve all teh way into the Passenger Side Front Wheel well, where the New Hard Line will meet the SS line.
ANy pics or advice???
THanks!!!
-George
Old Jun 21, 2004 | 06:36 AM
moto27cm's Avatar
Default Re: Need help Installing Passengerside Front Hard Brake Line (MugenB16A2)
You should be able to do it. I believe there is a grommet that the line goes through in the inner fender. Try popping that out to make more room, then reinstall when finished. Its not THAT tight in there. Good luck.
Old Jun 21, 2004 | 09:01 AM
MugenB16A2's Avatar
Yeah, i seen the grommet before, not a problem, I am just worried I might get caught up somewhere, and those hardlines break easily under pressure. Oh well, Here I go!!!!
Thanks
supaman
Aug 1, 2016 05:27 AM
95skunkedgsr
Suspension & Brakes
Oct 20, 2013 08:02 AM
jvtec95
Aug 24, 2006 05:13 PM
Deo
11
Dec 4, 2005 09:09 PM
turbospool
Aug 10, 2003 11:38 AM
