Allmotor H22 catch cans?
Old Jun 20, 2004 | 10:12 PM
jdmcivicferio's Avatar
Default Allmotor H22 catch cans?
How did you guys run your catch cans on your allmotor h22's?
Old Jun 21, 2004 | 06:34 AM
577HondaPrelude's Avatar
Default Re: Allmotor H22 catch cans? (jdmcivicferio)
PCV system:
(intake before TB)->(crank case in, passenger side)->(crank case out, driver side)->(PCV valve)->(Catch can)->(intake after TB)
Old Jun 21, 2004 | 06:35 AM
lildrgn2.0's Avatar
New User
Default Re: Allmotor H22 catch cans? (577HondaPrelude)
any one got a picture that they can post up? I would like to see / discuss these?
Purpose?
Old Jun 21, 2004 | 06:52 AM
Speedra500's Avatar
Default Re: Allmotor H22 catch cans? (Lildrgn)
purpose is to catch oil before it gets in your intake manifold and gets nasty and puts oil in your intake
Old Jun 21, 2004 | 07:42 AM
sharkcohen's Avatar
Default Re: Allmotor H22 catch cans? (Speedra500)
I'll post a pic of mine in a bit when I have a chance.
Old Jun 21, 2004 | 07:57 AM
jmcclell's Avatar
I am running a catch can setup on my H22 with ITBs.
I have found that the PCV valve does not work correctly if you try to vent the gases to the atmosphere after the catch can. It makes the car VERY smokey.
I have the following setup:
Hollowed out PCV > Catch can > hose out the bottom of the car.
Old Jun 22, 2004 | 05:29 PM
Default Re: Allmotor H22 catch cans? (jmcclell)
pics/diagrams?
Old Jun 23, 2004 | 06:29 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">PCV system:
(intake before TB)-&gt;(crank case in, passenger side)-&gt;(crank case out, driver side)-&gt;(PCV valve)-&gt;(Catch can)-&gt;(intake after TB)</TD></TR></TABLE>
That's sort of a diagam, and is the right way to do it.
Old Jun 23, 2004 | 07:01 AM
bdb's Avatar
bdb
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 577HondaPrelude &raquo;</TD></TR><TR><TD CLASS="quote">
That's sort of a diagam, and is the right way to do it.</TD></TR></TABLE>
I do have mine currently installed as described above, but after some searching around I've seen that the B series blocks are using upto 2 breather ports (and much larger plumbing) than our H blocks. So, is it possible and beneficial to run a more advanced breather system as shown on this B series block?
Old Jun 23, 2004 | 07:32 AM
Daemione's Avatar
Default Re: Allmotor H22 catch cans? (bdb)
I don't really get how that one would work . . . . why is there a return line teed back into the outlet? And both of those outlets are coming from under the intake manifold (not present, obviously) - what about the stock PCV outlet?
Old Jun 23, 2004 | 08:36 AM
Kool-Lude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 577HondaPrelude &raquo;</TD></TR><TR><TD CLASS="quote">PCV system:
Mine is set up as noted above except for the PCV VALVE...it's AFTER the catch can, on top of my Morroso (replaces the vent into the atmosphere).
Old Jun 23, 2004 | 02:24 PM
that is a completely different catch can system, that motor comes factory with a catch can so B series are out of the question, if anyone has pics of there H series one installed that would be great
Old Jun 23, 2004 | 08:33 PM
sharkcohen's Avatar
Well, I don't have a good pic of mine. I replaced the PCV valve in the valve cover with an elbow, ran a hose from there to the side of my Moroso can, put a PCV valve on the top of the can, and ran a hose from the valve to a port between the throttle body and the blower. It works, I get several ounces of an oil/water mix in it every three months (the water is from condensation in the can).
Old Jun 23, 2004 | 09:54 PM
Default Re: Allmotor H22 catch cans? (sharkcohen)
hmm sounds good, so what do you do with the point where the pcv was going to the intake manifold?
Old Jun 23, 2004 | 10:32 PM
sharkcohen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcivicferio &raquo;</TD></TR><TR><TD CLASS="quote">hmm sounds good, so what do you do with the point where the pcv was going to the intake manifold?</TD></TR></TABLE>
Who me? There's a blower where the intake plenum used to be
Old Jun 27, 2004 | 01:29 PM
pics?
Old Jun 27, 2004 | 09:33 PM
Speedra500's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sharkcohen &raquo;</TD></TR><TR><TD CLASS="quote">Well, I don't have a good pic of mine. I replaced the PCV valve in the valve cover with an elbow, ran a hose from there to the side of my Moroso can, put a PCV valve on the top of the can, and ran a hose from the valve to a port between the throttle body and the blower. It works, I get several ounces of an oil/water mix in it every three months (the water is from condensation in the can).</TD></TR></TABLE>
You are probably putting alot of excess oil in your catch can because you have your PCV after your catchan, this would make your catch can the same pressure as your crank case at all times so oil can get shot in there even under regular conditions, the purpose of your catch can is to catch the oil when your PCV valve opens, not when it is closed
Old Jun 28, 2004 | 05:34 AM
sharkcohen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speedra500 &raquo;</TD></TR><TR><TD CLASS="quote">You are probably putting alot of excess oil in your catch can because you have your PCV after your catchan, this would make your catch can the same pressure as your crank case at all times so oil can get shot in there even under regular conditions, the purpose of your catch can is to catch the oil when your PCV valve opens, not when it is closed</TD></TR></TABLE>
You may be right about this. I've thought about this, and have been considering moving the pcv valve back to its stock location and then putting an elbow at the top of the can.
In any case, what I get in the can really isn't that much oil. There is a lot of water from condensation in the can over time, looks like chocolate milk or well brewed espresso, and the total volume is like 4 ounces every 3-4 months.
Old Jun 30, 2004 | 11:41 AM
routed in in yesturday seems to work pretty good
Old Jun 30, 2004 | 03:52 PM
precord96's Avatar
Cant see the catch can in the pic, but you can see how it's routed.
Old Jul 3, 2004 | 07:51 AM
Kool-Lude's Avatar
In any case, what I get in the can really isn't that much oil. There is a lot of water from condensation in the can over time, looks like chocolate milk or well brewed espresso, and the total volume is like 4 ounces every 3-4 months.</TD></TR></TABLE>
I get the same "well brewed espresso", but at a volume of 4 ounces every 6 months. I'm sure your blown engine accounts for the add'l usage over mine.
Any more thoughts on moving the pcv valve back to its stock location? I guess we could use the stock pcv valve then too, right? (I'm using Fram PV294..and its like having a rattle snake under the hood)
Old Jul 3, 2004 | 09:11 AM
ebp 99 si's Avatar
Default Re: Allmotor H22 catch cans? (Kool-Lude)
i was wondering also on how to install my catch can but this is for a turbod h22
gizmoto2000
Feb 20, 2012 10:39 PM
eggie75
Jan 8, 2008 06:17 PM
h22sedan
Dec 3, 2006 05:34 PM
jdmcivicferio
Jan 29, 2004 05:21 AM
quickchris
Nov 21, 2003 05:58 AM
