DSM T25->what size plug will fit the O2 hole in the Housing?
Old Jun 20, 2004 | 08:40 PM
T-RO's Avatar
Default DSM T25->what size plug will fit the O2 hole in the Housing?
I need to find something that will plug the O2 sensor hole on the DSM T25 O2 housing (also called "elbow").
Any ideas? I've tried a few things but cant find a bolt thats the right size to seal it well. The last bolt popped out after a few miles and I had to drive the rest of the way home with that hole open. (thats not gonna hurt anythign is it?)
If i cant find anything then i'll probably hit the junkyard and pull an O2 sensor and stick it in there. I just dont want to go way out there if I can get a bolt locally.
Old Jun 20, 2004 | 11:07 PM
Jaker's Avatar
Default Re: DSM T25->what size plug will fit the O2 hole in the Housing? (T-RO)
Large size spark plug will fit. The ones that use a 13/16" socket (like Ford V8, etc...).
Old Jun 21, 2004 | 06:08 AM
Flamenco-T's Avatar
try 18 x 1.5mm
stan
Old Jun 21, 2004 | 06:36 AM
Adriano's Avatar
Default Re: DSM T25->what size plug will fit the O2 hole in the Housing? (Flamenco-T)
just put a wideband o2 there and call it a day...
Old Jun 21, 2004 | 06:58 AM
T-RO's Avatar
lol I would if I could.
Old Jun 21, 2004 | 01:00 PM
T-RO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flamenco-T &raquo;</TD></TR><TR><TD CLASS="quote">try 18 x 1.5mm
stan</TD></TR></TABLE>
...and ocne again Stan wins the prize!!! The bot is 18x1.5mm like you said. Good luck finding one folks, you have to hit up a specialty bolt place Ace Hardware doesnt have them. I got mine from a friend at a local turbo shop.
Old Jun 21, 2004 | 01:05 PM
gritsak's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T-RO &raquo;</TD></TR><TR><TD CLASS="quote">
...and ocne again Stan wins the prize!!! The bot is 18x1.5mm like you said. Good luck finding one folks, you have to hit up a specialty bolt place Ace Hardware doesnt have them. I got mine from a friend at a local turbo shop. </TD></TR></TABLE>
just about any muffler shop should have a plug for 02 sensors
enriquez2000
Dec 23, 2011 05:49 PM
unrefined7
12
Jan 3, 2006 04:36 PM
HYREV2NR
May 21, 2005 12:26 PM
phiberoptik
Jun 8, 2004 12:43 PM
herde1724
May 4, 2004 09:32 AM
