BUDGET BOOST under $300!
Old Jun 20, 2004 | 05:46 PM
RACINGLIFE's Avatar
Default BUDGET BOOST under $300!
mad props to ECOLOGY AUTOWRECKING and all the sik scrapyards everywhere.
if you know how to do this, might want to skip this, n e ways, a turbo kit can put together, a fully functional turbo boosting 6-14lbs. boost complete w/ front mount i/c, i/c piping, b.o.v., downpipe, hoses, mising link bleeders, cast iron manifold, custom adapter and more.
ONLY for d-series motors!!!
the $hit boost hard and might blow your motor depending on driver and respect of car, also wheter you have a stock long block or built , you know?
Old Jun 20, 2004 | 05:54 PM
Hatchbslo's Avatar
So why don't you tell us how to do it.
I'm curious even thought I'd be afaid to Scrap yard boost my car
Old Jun 20, 2004 | 06:00 PM
CaptainCivic's Avatar
thats wonderful, now tell us
Jim Truett's Avatar
Default Re: (Hatchbslo)
You can JY turbo most anything if you can fabricate. http://www.homemadeturbo.com
Old Jun 20, 2004 | 06:01 PM
senpai's Avatar
Default Re: BUDGET BOOST under $300! (RACINGLIFE)
yea, and no fuel management, that's why it's going to blow ... yay!
Old Jun 20, 2004 | 06:30 PM
RACINGLIFE's Avatar
Default Re: BUDGET BOOST under $300! (maztur)
for fuel management i use bleeders
i bought them @PETCO, the fish tank bleeders that only releive pressure when boosting, so the MAP sensor is stock at idle or non-boost driving, then when you full throttle, the valve releases preasure tricking the ECU to thinking only more air is coming in but letting it know you have forced induction now, this will increase the fuel suplly slightly enough to boost 6-7lbs boost daily driven and pretty hard all the time. YES anything higher than 7lbs. boost, you will need at least a fuel pump and regulator, or afc controller. i posted a full summary in the civic/crx forums describing alot about the design and concept of this kit. also prices!
be safe when boosting!
Old Jun 20, 2004 | 06:44 PM
Happyman's Avatar
Welcome to last year
You are a moron and will probably blow up your motor in a short amount of time. In no way will putting check valves raise the fuel psi. lol...I suggest getting an FMU/FPR soon.
Old Jun 20, 2004 | 07:21 PM
duh blacksheep's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACINGLIFE &raquo;</TD></TR><TR><TD CLASS="quote">for fuel management i use bleeders
be safe when boosting! </TD></TR></TABLE>
wow...i think i just learned something.....
about the people that post on this board, well actually...i already knew that
Old Jun 20, 2004 | 07:26 PM
Jim Truett's Avatar
Go to http://www.pgmfi.org and learn how to tune it properly.
projectef
15
Jul 9, 2007 04:42 PM
slowspool
Feb 14, 2004 05:35 PM
turboteg96
Apr 11, 2003 07:50 PM
ej000001TypeR
Dec 2, 2002 03:09 PM
phase12gsr
Apr 10, 2002 03:30 PM
