Converting from LS-Turbo to LS/VTEC Turbo, confused on a few aspects...timing belt...
Old Jun 20, 2004 | 08:41 AM
wade's Avatar
Default Converting from LS-Turbo to LS/VTEC Turbo, confused on a few aspects...timing belt...
with a vtec head on a LS block with a LS water pump and LS oil pump, do i still use a LS timing belt or a VTEC timing belt (if they are different) because a vtec head is taller which might require the longer timing belt.
thANks!
i guess to do the swap, i must get the golden eagle dowels for the head, lsvtec oil line kit, p28 ecu socketed for hondata and a LS headgasket plus the 2 vtec wires to run.
Old Jun 20, 2004 | 08:46 AM
calvinPGMFI's Avatar
Default Re: Converting from LS-Turbo to LS/VTEC Turbo, confused on a few aspects...timing belt... (wade)
the wiring part is good. i beleive i never did an ls swap.
but their must be a lot of info on the HT site
Calvin
Old Jun 20, 2004 | 09:28 AM
ragerized's Avatar
from what ive heard, if you use the ls water pump, ls timing belt. if you use a gsr/itr water pump, then a gsr/itr timing belt.
Old Jun 20, 2004 | 09:30 AM
Rod.'s Avatar
gsr belt or typer belt
Old Jun 20, 2004 | 09:41 AM
B18C1CYA's Avatar
you use the timing belt that belongs with the water pump, it dosent matter with oil pumps but i would use a vtec one i recomend a 94 gsr one, so for example if you have a ls water pump you use a ls timing belt and vise versa
Old Jun 20, 2004 | 10:29 AM
rondigs's Avatar
Default Re: Converting from LS-Turbo to LS/VTEC Turbo, confused on a few aspects...timing belt... (B18C1CYA)
Make sure to use GSR head studs.
Old Jun 20, 2004 | 01:01 PM
wade's Avatar
Default Re: Converting from LS-Turbo to LS/VTEC Turbo, confused on a few aspects...timing belt... (rondigs)
thanks! looks like wit a LS water pump i need LS t-belt. i will continue to use my newer LS oil pump. thats alot of work to do a oil pump.
Old Jun 20, 2004 | 01:03 PM
wade's Avatar
rondigs, even wit a LS block and B16 head... i need the GSR head studs? arnt all vtec head studs the same?
Old Jun 20, 2004 | 01:34 PM
AznInvasion's Avatar
i got all the parts for an LS vtec setup hit me
up
i even got pistons and rods
arp headstuds
hondata gasket
lsvtec kit
itr water pump, oil pump, timing belt
all brand new
Old Jun 20, 2004 | 02:21 PM
wade's Avatar
Default Re: Converting from LS-Turbo to LS/VTEC Turbo, confused on a few aspects...timing belt... (AznInvasi
AZN, r they GSR head studs? if so, how much? how much for the hondata gasket? is the gasket for b16 heads itr gsr heads?
da.nizzle
May 5, 2008 12:10 PM
prolifik22
Feb 10, 2008 06:35 PM
turbo_b16_ex
Oct 4, 2005 11:06 AM
SL0WEGG
May 5, 2005 02:51 PM
vtecb20coupe
Dec 10, 2003 12:15 PM
