My calipers fell appart due to excessive rust - What now?
They are simply to old and to damaged to be rebuild, so I need a new set for my 1992 Civic VTi (http://eg0.sprengt.net).
What calipers would you recommend to get? OEM or aftermarket, doesnt matter as long as the quality and price is good.
Thanks!
T
Thanks!
T
Sounds like a good time to do a gsr brake upgrade. Or just replace the worn out parts with identical new/ better cndition used ones.
You can't go wrong using oem parts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsVtec92Hatch »</TD></TR><TR><TD CLASS="quote">this thread is WORTHLESS without pics...</TD></TR></TABLE>
Yeah, no ****. A calliper actually falling appart from rust. I wanna see this.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IslandSi »</TD></TR><TR><TD CLASS="quote">
**** i can go look at one right now...
Walk down stairs and look at my old one
If you have alot of money..i would get spppppooonnnn calipers
</TD></TR></TABLE>**** i can go look at one right now...
That is one rusty caliper/rotor
The VTi is the top of the line model, right? If so your stock brakes are probably equivalent to an Integra GSR's (not sure of the European designation). I'd check out http://www.fastbrakes.com or http://www.wilwood.com
These guys do recon calipers, the VTi has the 262mm disks up front, bigger calipers than the 240mm disk civic.
http://www.brakesinternational.com/
nefariousyellow
Feb 11, 2008 08:55 PM
Bill Hook
10
Sep 8, 2003 06:26 AM
