msd sci and bosch coil bad idle
Old Jun 19, 2004 | 01:18 AM
jazz215's Avatar
Default msd sci and bosch coil bad idle
just installed a msd sci+ and bosch coil. now my car really has a hard time idling...
I double checked my wiring... removed iacv and cleaned. readjusted my idle. according to my afc.. its idling from 700 to 760.. but it feels so ruff. i tried changing the plug gap from .28 to .31 still sucks.
when driving, as soon as i hit around 3.5k its stutters... but after that, it feels good. i am running 1 step colder ngk plugs and my wastegate set for 6psi.
im going to wire up the msd box with the stock coil, but if that doesnt work what should i check next? tia
Old Jun 19, 2004 | 12:57 PM
jazz215's Avatar
bump
Old Jun 19, 2004 | 09:24 PM
jazz215's Avatar
ok i bought a new msd blaster 3 coil, installed it.. still had a ruff azzz idle. after researching i found this site. http://overboost.com/story.asp?id=355
i have the autolite 7mm plug wires from autozone.. i guess i was getting major crossfire. I separated the wires as far as possible and runs like a champ now.
Old Jun 19, 2004 | 10:19 PM
dogfood's Avatar
Default Re: (jazz215)
autozone is garbage and so is autolite, as well as pepboys. pick up some ngk, or oem. Good call on the coil though
byc_cb7
Aug 28, 2009 10:15 AM
THEDirtyDseriesWOOT
Oct 2, 2006 04:52 PM
Cpt Ben
Apr 18, 2006 10:21 PM
IloveNewt
Apr 23, 2004 02:26 PM
