spark plugs wire for under 50 bux...where??
Re: spark plugs wire for under 50 bux...where?? (BLUE EH3)
i believe autozone or pepboys will do the trick. if your talking about performance. you get what you pay for, to an extent.
Re: spark plugs wire for under 50 bux...where?? (JMaxx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JMaxx »</TD></TR><TR><TD CLASS="quote">i believe autozone or pepboys will do the trick. if your talking about performance. you get what you pay for, to an extent.</TD></TR></TABLE>
uhhhh....no
OEM or NGK all i run in any honda
uhhhh....no
Re: spark plugs wire for under 50 bux...where?? (hondaeg8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaeg8 »</TD></TR><TR><TD CLASS="quote">what kind of harness are you looking for? get some stock NGK wires.</TD></TR></TABLE>
For most Sumitomo are stock wires... Not NGK...
I would recomend buying STOCK wires over any aftermarket ones... there have been a couple of wire tests that have shown the stock wires delivering more power than other wires including NGK...
Stock are the best and I believe they're around 13 bucks each from hondaautomotiveparts.com
Re: (Turbo E 604)
As someone stated above, you will get the most of OEM wires...
Performance, durability, piece of mind - you name it!!!
Don't learn the hard way!!!
OEM all the way!!!
OEM all the way!!!
Re: (BLUE EH3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 »</TD></TR><TR><TD CLASS="quote">are gsr,b16, itr, ls wires all the same?</TD></TR></TABLE>
i believe so. http://www.sparkplugs.com has ngk wires for $51 and some change. Also, napa autoparts should be able to get ngk stuff.
Re: spark plugs wire for under 50 bux...where?? (99blackcivicSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99blackcivicSi »</TD></TR><TR><TD CLASS="quote">
uhhhh....no
OEM or NGK all i run in any honda</TD></TR></TABLE>
i was just saying they work, and making a point. he didn't specify any preference. and hondas aren't that special But i agree with you.
uhhhh....no
Jaydeep
14
08-17-2004 10:24 PM
