Need serious HELP for friend's Civic Hatch
Old Jun 18, 2004 | 11:15 PM
Buktheng's Avatar
Default Need serious HELP for friend's Civic Hatch
He got a hatch with a 94 LS swap and have some major problems. It overheats like a motherfu*ker and it sucks up the coolant like no other. Today, we were wondering why it sounded so bad and found out there's no coolant. We bought some, poured it in, and drove off. Checked it again acouple miles later and the coolant is all gone again. There's no leaks because we checked and no coolant hits the ground. Is there an explanation what it could be? He has a 92 CX with a LS swap, stock except an intake on it.
It's really annoying because on the temp gauge, it's all the way on HOT and doesn't go down. The dude told me something about obd2 ain't compatible with obd1 or some **** but I don't remember. Can any of you guys tell me what to check and what to do to fix it?
Old Jun 18, 2004 | 11:19 PM
4g4drb17's Avatar
Default Re: Need serious HELP for friend's Civic Hatch (Khoifather)
you blew a head gasket probably
Old Jun 18, 2004 | 11:22 PM
Buktheng's Avatar
Default Re: Need serious HELP for friend's Civic Hatch (4g4drb17)
How would I check to see the head gasket is blown?
Old Jun 18, 2004 | 11:23 PM
Benzo2NED's Avatar
I'm a Jackass
do a compression test
Old Jun 18, 2004 | 11:27 PM
hondaeg8's Avatar
Default Re: (Benzo2NED)
pretty sure its the head gasket.
check the oil......is it watery?
check the oil cap....is there white stuff under the cap?
is there white smoke coming from the exhuast?
if its not dripping anywhere, there's pretty much no where else for the coolant to go besides in the head and out the exhuast. the temp should and the significant loss of coolant should tell you right away that the headgasket is bad. i wouldn't drive the car anymore until its changed out.
Old Jun 18, 2004 | 11:30 PM
Buktheng's Avatar
Default Re: (hondaeg8)
White smoke definitely comes out the exhaust when he steps on the gas. But the thing is, it has the stock civic radiator in the hatch, shouldn't he need an Integra radiator to cool the engine?
Old Jun 18, 2004 | 11:32 PM
BatuKing's Avatar
Default Re: (Khoifather)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Khoifather &raquo;</TD></TR><TR><TD CLASS="quote">White smoke definitely comes out the exhaust when he steps on the gas. But the thing is, it has the stock civic radiator in the hatch, shouldn't he need an Integra radiator to cool the engine?</TD></TR></TABLE>
I take it your trying to avoid the answer.. if you are loosing coolant and there is no leaks.. do the math.. its getting burned.. so you have a blown headgasket..
So NO putting a TEG radiator will not help it. and FYI there are alot of people running stock EG radiators with B series motors.
Old Jun 18, 2004 | 11:39 PM
hondaeg8's Avatar
Default Re: (BatuKing)
its the HEAD GASKET!
its not the radiator. i have been using the stock eg radiator with all my integra motors. i've been superchaged and turbocharged with my ls motors and have had no overheating problems due ot the radiator. i now have a gsr with nitrous and have no problems using my stock eg raditor.
change the head gasket. its a lot of work, but it needs to be done before you mess things up even more. you could warp the head or something if you/he keeps driving it.
park it before things get worst
Old Jun 18, 2004 | 11:41 PM
Buktheng's Avatar
ok dudes, thanks for the help!
Old Jun 18, 2004 | 11:47 PM
BatuKing's Avatar
OH and BTW since you ran out of fluid. your head is warped for sure. so you will need to send it to a machine shop to get fixed.. and DONT drive it or fire it up anymore untill you get it fixed
Old Jun 18, 2004 | 11:53 PM
hondaeg8's Avatar
Default Re: Need serious HELP for friend's Civic Hatch (BatuKing)
if you need another head, hit me up.i have an extra ls head i can sell you.
good luck
Old Jun 19, 2004 | 01:48 AM
91civicDXdude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">It's really annoying because on the temp gauge, it's all the way on HOT and doesn't go down.</TD></TR></TABLE>
It seems like he seems to think this is the worst problem..... that damn annoying temperature gauge just wont stop reading all the way hot when theres no coolant in the engine!
ramonjones16
Sep 1, 2009 10:20 AM
black0hatch
Jan 22, 2008 10:00 AM
ALMXDUPINTEGRA
May 11, 2005 11:05 AM
HondaFanatic708
Apr 12, 2004 02:45 PM
veejay
Jun 30, 2001 09:02 AM
