D16Z6-T went to the track last night
well i went last night to the local track to test my lil baby
was not too happy with my results
my best ET of the night was 14.7 @ 91 mph
my freaking clutch was slipping like a ****.....
i can tell during 2nd and 3rd, the rpms rising fast, then comming down and slowly comming back up........ sucked ***......
time for a real clutch... ACT 6 spuck or someshit.......
my best trap speed during these runs was 95 mph........
i was looking foward towards a better time.. but i guess i wasnt able to hook the power.......
walk out with a slipping clutch, broken axles, faded brakes, and a 1st gear that now is acting up
i guess i have to retest it soon....
until then, shes going to have to be taken easy on
RT/-----------0.908
60'------------2.220
330ft----------6.239
ET@594ft-----8.945
1/8 ET--------9.548
1/8mph ------74.71
1/4 ET--------14.783
1/4mph-------91.06
Modified by USDM 4G VTEC at 9:19 AM 6/18/2004
RT/-----------0.908
ET@594ft-----8.945
1/8 ET--------9.548
1/8mph ------74.71
1/4mph-------91.06
whats your setup?
Around 200 wheel?
Im looking for a nice tranny setp myself, looking for the best combo of a nice clutch for nitrous and a lightenned flywheel, pretty pricey from what Ive seen though
Around 200 wheel?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude »</TD></TR><TR><TD CLASS="quote">post your whole time slip....</TD></TR></TABLE>
Agreed.. Whats engine are you running, turbo, psi, fuel management??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves »</TD></TR><TR><TD CLASS="quote">
Agreed.. Whats engine are you running, turbo, psi, fuel management??</TD></TR></TABLE>
Also..what clutch were you using that slipped so much on you?
OUCH...that sucks what clutch are you running??? Im working on turbo'ing my z6, hope you get it all sorted out cause my Z6>your Z6-T
...just playin....and whats your setup?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by green91 »</TD></TR><TR><TD CLASS="quote">should be closer to 13s with good clutch with that set up, i would think</TD></TR></TABLE>
I would guess maybe low 14's if its tuned correctly..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by azroth »</TD></TR><TR><TD CLASS="quote">A setup like that with the right tuning should be over 200 WHP. I would say most of whats worng is the slipping clutch. After that, go get some real emgin managment.</TD></TR></TABLE>
A 14b @ 9psi on a vafc hack.. I might be wrong but I have a hard time believeing that would put out over 200 whp..
A 14b @ 9psi on a vafc hack.. I might be wrong but I have a hard time believeing that would put out over 200 whp..</TD></TR></TABLE>
I have a hard time believing a d16y7 @ 5psi is running 13s...
I have a hard time believing a d16y7 @ 5psi is running 13s...</TD></TR></TABLE>
exactly, and he is saying that this setup is only good for 14's...hmm...
it can be around 200whp with this setup, just correct tuning...someone had about that with a turbo zc with a vafc hack...
woa
where this Y7 and 5 psi came from???
anyways i should be able to easyly have 180-200 whp
if i did a 14.7 @ 91 mph... i am guessing nwith the real grip i am missin, i can go over the damn top speed i had today of 95 mph... and been able to pull the 14.0 or maybe 13.99 with my hoosier drag slicks
i have a y7/z6 mini-me with a 14B@9-10psi. I was running VAFC hack with 450cc DSM injectors at the time...
i ran the 1/8 mile on a set of pure **** hoosier road race treaded tires
60' 2.3
1/8 9.3
MPH 83mph
this was on new OEM stock clutch. Granted, its only .2 faster, but my mph is a lot higher. I spun the tires all the way through 2nd gear, and this is even with granny shifting into 2nd to avoid spinning. i have a video to back it up.
I think your car has a little more potential...get a clutch and flywheel. I recently installed a (used) clutchmasters stage 3 clutch & aluminum flywheel and it grips great. havent had a chance to take it to the track since I bought that clutch setup and a set of Dunlop SP SPort slicks mounted on Diamond Racing 13x7" wheels, but with a 2-2.1 60 i'm hoping for 8.3-8.6@83-85mph and ~13.5 1/4
Im not trying to steal your thread, i just like to compare to people with similar setups
60' 2.3
1/8 9.3
MPH 83mph
http://www.prosportcompact.com...2.mpg
If you want I can unplug the boost controller like it was when I ran and shoot a vid of the boost gauge for you to see..
Modified by tgreaves at 10:46 AM 6/21/2004
Modified by tgreaves at 10:50 AM 6/21/2004
slammin86
Oct 21, 2007 05:52 AM
USDM 4G VTEC
Jun 18, 2004 06:43 AM
92HB_HB
Apr 16, 2002 03:23 PM
