I need help finding parts inside distributor.
Okay, taking out the ignition coil to have it tested, nearly every screw was stripped already. I need the two screws that hold the ignition coil in place. I searched on g2ic, and found that somebody had went to lowes and bought two 10x32x1 1/4 screws and they worked. So that might work. I also need the two screws that hold the wires onto the terminals on the ignition coil. The (+) and (-) screws. I also need the wire that goes from the igniter to the positive terminal. It broke and is pretty much rendered useless. The dealer told me that they don't sell them. Only a whole kit. Anybody ever run into this, if so...what did you do. Also, I didn't have a set screw for the rotor when I changed it. I probably need that to. THanks.
Hybrid Invasion
Nov 25, 2007 11:50 PM
AndyD
Mar 30, 2006 05:24 PM
d16rice
12
Apr 3, 2005 06:09 PM
