rear brake pad replacement. Caliper compressor?
I ordered some new Axxis MM pads for my 95 accord ex 4dr. I planned to install them myself, but I talked to a guy at a local shop and he said that they are harder to do because you need a caliper compressor. I'm not sure what the frick that was all about, maybe the caliper compressor for the piston? I thought you just turned the piston clockwise with like a metal spatula or something. Is it different on 95 accords? Thanks guys.
Unless you're changing out a caliper, you really don't have to bleed your brakes. Only if you really want to change your brake fluid because of time. If it were me, I wouldn't worry about the bleeding the brakes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D21X »</TD></TR><TR><TD CLASS="quote">C-Clamp usually works pretty good</TD></TR></TABLE>
Not on the rears. The screwdriver is the way to go.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -RedneckDave- »</TD></TR><TR><TD CLASS="quote">
Not on the rears. The screwdriver is the way to go.</TD></TR></TABLE>
Yup C clamp can do damage. Just use a big *** screwdriver
In this post they say you need to bleed the caliper. Is he right?
https://honda-tech.com/zerothread?id=157444
MygirlsCoupe
Aug 10, 2004 08:58 AM
