how far can you take a 38mm wastegate, safely???
Old Jun 17, 2004 | 09:44 AM
GSRswapandslow.
Guest
Posts: n/a
Default how far can you take a 38mm wastegate, safely???
a friend is starting on his 2.0L turbo...and i'm helping him find parts...
what would you run for 500whp, wastegate wise? is the 38mm tial safe at that level, or shoudl he upgrade to something else???
Old Jun 17, 2004 | 09:46 AM
GSRswapandslow.
Guest
Posts: n/a
and what spring would be the best spring to run around 10psi ish? i can't remember the specific spring rates...sorry
Old Jun 17, 2004 | 09:50 AM
tthame1's Avatar
Default Re: (GSRswapandslow.)
You don't want to run more than double the value of the wastegate spring, so you can't determine that until he decides how much boost he will run.
As far as wastegate sizing, directly from Tial's website: "Contrary to popular belief, larger higher HP applications do not necessarily require the largest wastegate available. The lower the boost pressure you are gunning for the larger your wastegate needs to be. An engine/turbo combination that is set to 25+psi has a smaller wastegate flow requirement than the same application set to 7 psi. This is because the wastegate is used to lower the boost not raise it, the lower the boost pressure is set the more flow the wastegate must allow."
Old Jun 17, 2004 | 10:42 AM
RyanEJ8's Avatar
Default Re: (tthame1)
Tial's website is correct. The 38mm will be fine.
Old Jun 17, 2004 | 12:48 PM
Tinker219's Avatar
Default Re: (RyanCivic2000)
35mm, 1 bar spring. 22psi on my srt4, very solid and controlled.
Old Jun 17, 2004 | 01:15 PM
turbo*s2k's Avatar
Default Re: (Tinker219)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tinker219 &raquo;</TD></TR><TR><TD CLASS="quote">35mm, 1 bar spring. 22psi on my srt4, very solid and controlled.</TD></TR></TABLE>
Pretty much the same here. 38mm wastegate / 1 bar spring / 23 psi.
Old Jun 17, 2004 | 01:49 PM
GT61 this 1.8t's Avatar
Default Re: (TurboChrgd_Civic)
i ran the tial 35mm...
ran 25-28psi made 441wheel...
worked like a champion!
saw some minor boos creep up top tho... id set to 25psi and end up at about 28psi
Mar 18, 2004 11:30 PM
EH2LS
Sep 27, 2003 01:02 PM
ebp 99 si
Jun 15, 2003 07:45 PM
Greg123
Jan 11, 2003 12:25 AM
