best way to install axle
Old Jun 16, 2004 | 11:51 PM
david90's Avatar
Default best way to install axle
Put it in the tranny first or the hub first?
Old Jun 17, 2004 | 02:25 AM
slateraptor's Avatar
Default Re: best way to install axle (david90)
tranny first!!! i hope you aint a light-weight like myself cause you're seriously gonna have to push hard and straight (the set ring has to go past 2 grooves in the tranny...you'll know what i mean when you get started). don't push from the boot or shaft either, or you'll run the risk of seriously damaging you joint. you shouldn't have nearly as much trouble putting the hub side on.
Old Jun 17, 2004 | 08:39 AM
david90's Avatar
I did the swap and I had to tap it with my hammer for it to go into the tranny and the hub. Did that damage anything? I'm already done and it drives pretty good.
Did u do it yourself or with a pal? I did it with a pal and I couldn' imaging doing it myself.
gcrash
Oct 4, 2009 12:56 PM
tallblondkid
Mar 1, 2009 11:02 PM
rexxb16
Aug 29, 2007 09:56 AM
kanzdj1
Sep 19, 2003 02:45 PM
VTEConly
Jun 22, 2003 10:44 AM
