Taking out the pin that holds the shiftlinkage on...help me please!
i put a GSR motor in my del sol and everything is ready to go but i have a big problem... The pin that holds in the shiftlinkage is stuck. Ive tryed every thing to get it out used a punch th same size as the pin and beat on it..nothing used a 10mm bolt and threaded it in a little and hit it with power...nothing so i thought about drillin it out but when i got it going the drill broke off inside the pin... Im so screwed if anyone can help i would thank u much...
yeah i had the same problem... i just constinatly beat the hell out of it and the bitch pin finally moved... did you maybe spray it with a lil lube? then give it a few good cracks?
I used one of the long 10mm bolts that holds the ac condensor to the bracket, I had extra bolts... not sure about you, I had the shifter in neutral the hold time I was banging on it and no luck, then I put it in gear (1st) for some reason it got easier... Good Luck
there is a thread SOME were around here that gives you the exact sized punch to use and how to get it out easily without ****** it up. i have no clue what to search for but its here. maybe check some of the transmision removal threads
use an 8 MM punch. if you use a screwdriver or anything else that's not the correct size it will just simply expand the pin as you pound on it thus making it not want to come out.
we had the same problem. take the linkage out with the motor/tranny and hit it out from the other side. much easier this way.
i hate these fuking pins. i always hit them out with a 12mm bolt. meaning the head is 12mm. the bolt will fit perfectly ontop of the pin and slide right out.
then when reinstalling i just use that 12mm bolt and put a nut on the other side of it. this way i dont have to dick with it again. it works everytime and ive never had a problem with it falling off or breaking
yeah...but when you use the nut and bolt, doesn't that make your shifter real lose?
i have a nut and bolt on mine right now and my shift is damn lose. i haven't missed a gear, but i would rather have a pin instead of the nut and bolt.
Nation5
14
Oct 5, 2016 02:27 PM
rasinhell
14
Feb 25, 2008 04:01 PM
delsolnewkid
Mar 11, 2006 04:12 PM
