profec e-01 lost in outer space
Old Jun 15, 2004 | 06:33 PM
integ2's Avatar
Default profec e-01 lost in outer space
Hello, I purchased a profec e-01 bootst controller and I need some help. the instructions are not much help when it comes to detail. I make adjustments such as the gain and it does not seem to change anything. I need to know what the % means when setting the boost level and its relation to the gain setting. Also, the instructions do not tell me where to set the wastegate set screw. should it be all the way down or all the way out? I have the deltagate II. I understand that all the way down is 7 psi, but I have yet to see 7 psi of boost. It seems the engine has to wind up to 5k rpm before the boost will even climb to 5 psi. I feel maybe its user error, Please help, I'm confused.
_kiid
Nov 18, 2009 04:12 PM
hoskos
Feb 21, 2007 06:21 AM
turbotime
Sep 10, 2006 05:12 PM
slowater427
Oct 4, 2005 02:42 PM
integ2
Jun 15, 2004 06:44 PM
