LSD question
Old Jun 15, 2004 | 08:47 AM
nickatiah's Avatar
Default LSD question
whats a good one and I'm pretty sure it's not a DIY but any info would be helpful.
96' civic EX manual.
Old Jun 15, 2004 | 09:19 AM
kommon_sense's Avatar
Default Re: LSD question (nickatiah)
choices are quaife, and kaaz. There is also the phantom grip, aka phantom slip.
kaaz is a clutch style that requires occassional rebuilds, whereas the quaife is a gear diff, shouldn't require any additional servicing once installed.
http://www.exospeed.com
http://www.camp1320.com
There is also the OEM lsd from the civic vti-r which is basically a z6 tranny + lsd.
Old Jun 15, 2004 | 09:37 AM
nickatiah's Avatar
Default Re: LSD question (kommon_sense)
thanks man but about the install is that a pro only job. i know that there are no"user serviceable parts" of a Honda trans but you can at least see this one with the axles out
Old Jun 15, 2004 | 09:47 AM
Marauder's Avatar
You can install them yourself, but you should know how to work on tranny's. Its not for the faint at heart do-it-yourself mechanic. You will have to reshim the diff and check for the proper clearances.
I have a Kaaz LSD in my civic and love it. Although, considering you are supposed to change the fluid every 5000-6000 miles, and at $45 a can, I'd go with the Quaife instead. Although, it depends on your application, since lots of road racers use the Kaaz.
Old Jun 16, 2004 | 05:03 AM
nickatiah's Avatar
Default Re: LSD question (Marauder)
thanks you. anyone know a place in NC where it can get done
Old Jun 16, 2004 | 05:53 AM
AnToNy's Avatar
go with the quaife. as for a shop, i've heard a few good things about P-1 auto, i think there in fort mill, just south of charlotte. go to p1auto.com and find out.
johnclaunch
Nov 23, 2007 04:23 PM
DJ Nokturnal
22
Sep 5, 2003 02:17 PM
Kaizen
Jul 16, 2003 07:52 PM
meanm3
Jan 20, 2003 06:14 PM
