del sol si/civic
Hey Guys does anyone know what civic the del sol matches up with i mean with body and electrical, and is a stock del sol b16a ignition harness different then a civic si ignition harness?
thanks a bunch
thanks a bunch
i belive the s is like the dx becuse the map is the same .. and some other things so i would say they are the same in that aspect the linkages arent the same and the e brake cables arent the same .. but just my2 cents
del sol si is equivalent to the civic ex in terms of motor. del sol DOHC VTEC motor is similar to the new 99-00 Civic Si motor.
For the most part most of the civics, del sols, and integras are interchangeable. Just make sur eyou double check.
Exterior wise, del sol is very different from a civic. Just look at them. Electrical wise, very similar to civics...
Honda Tech Editor
Newsletter Archive
Sep 12, 2014 01:47 PM
bubbajim
29
May 12, 2003 04:47 AM
