Overheating Problem. Pro's Please HELP!@@!
Old Jun 14, 2004 | 04:16 PM
Red D Dragon's Avatar
Default Overheating Problem. Pro's Please HELP!@@!
Ok I have a mildly built all motor gsr, in my 94 hatch and first warm day i noticed it was overheating. i figured my civic radiator was shot.. so i got a C&R radiator. the car still would overheat, I got a mugen thermostat and it would still overheat... i got a mugen temp switch and it still overheats. When i drive on the highway i am at like 190degrees then i slow down and i go over 220 usually. so i gotta pull over wait for it to cool down. My fan kicks at 200degrees... it used to be 220 until i put the mugen switch in there. The headgasket is fairly new and there is no milky appearance in the oil and there is no oil in the coolant. and the water pump was replaced not too long ago. But my question is.. how can i find the problem. How do i check if its my water pump and how do i check if its my headgasket. I know someone has the answer. ANything would really help me out.. thanks. FYI i have a temp sensor installed on the upper radiator hose and thats what i am getting the temp readings from. so when the temps are 200 coming out of the motor the fan turns on... but the car still overheats..
Old Jun 14, 2004 | 06:04 PM
anyone? what are symptoms of a bad water pump?
Old Jun 14, 2004 | 06:48 PM
help... i'm overheating..........
Old Jun 14, 2004 | 07:38 PM
GZERO's Avatar
Default Re: (Red D Dragon)
a water pump that is damaged leaks from the breather hole.
Anyway, did you tried the radiator cap?
Old Jun 14, 2004 | 07:43 PM
Sunrise City Rider's Avatar
Default Re: Overheating Problem. Pro's Please HELP!@@! (Red D Dragon)
Bleed all the air from the cooling system...Start the car and let it warm up with the Radiator Cap off...Add water as needed...You may have a cracked or warped head???
Old Jun 14, 2004 | 09:15 PM
see the thing is the motor was just rebuilt not too long ago.. so i dont know whats up with it... well it was doing it with my stock radiator as well as my new radiator... and new thermo and switch.. i bled the coolant already many times..there's no air in it...and where is the breather hole?there are no leaks anywhere either.. **** this sucksgrrrrrrrr
Old Jun 15, 2004 | 01:17 AM
IVI's Avatar
IVI
did you flush the coolant? if it was the water pump you would see water pouring out under the car.
like someone said it might be a crack in the head.
Old Jun 15, 2004 | 03:47 AM
1.8turbolsvtec's Avatar
DOES THE OVER FLOW FILL WHEN YOU DRIVE IT AND ARE THE HOSES VERY HARD IF SO HEAD GASKET TIME
GOOD LUCK
Old Jun 15, 2004 | 07:34 AM
well my overflow has been filling up... do you think its the headgasket.. oh man.. ****.. time for a mugen headgasket haha.. i was hoping it would be something easier though.. i dont feel like taking the damn motor apart.. it was just put together not too long ago...grrr
Old Jun 15, 2004 | 08:17 AM
GZERO's Avatar
Default Re: (GZERO)
radiator cap
Old Jun 15, 2004 | 10:39 AM
Well i am like 100% sure its not the radiator cap.. it was doing it with my stock cap.. and it was doing it with my C&R high pressure cap.. so its gotta be something else
Old Jun 15, 2004 | 12:00 PM
egsleepercivic's Avatar
If its ok when your driving and heats up when your stopped, check to make sure your fan is actually turning on
Old Jun 15, 2004 | 05:26 PM
alright well after running a total diagnosis.. i am 99% sure its my headgasket which really pisses me off. but i was running my motor pretty advanced before.. and the thing that is giving it away is my overflow can keeps getting filled.. a sign of a blown headgasket.. i'll keep an update of what happens...
Old Jun 15, 2004 | 05:34 PM
GZERO's Avatar
not to keep insisting, but, a broken radiator cap does that as well, it does release the pressure but it doesn't let the radiator suck in water from the overflow tank, try to do a leakdown and see if you see the bubbles on the radiator neck
Old Jun 15, 2004 | 05:43 PM
ya but its not the radiator cap because... i know for a fact i was running like 22 degrees advanced for a while.. and that was my stock radiator stock cap.. now i have a c&r radiator with high flow cap and it does the same thing but its getting worse.. which i assume means the gasket is getting worse. either way i figure i will mill my head a little get some more compression and throw a new gasket on there.. just a lot of work i didnt feel like doing
Old Jun 15, 2004 | 05:48 PM
GZERO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Red D Dragon &raquo;</TD></TR><TR><TD CLASS="quote">ya but its not the radiator cap because... i know for a fact i was running like 22 degrees advanced for a while.. and that was my stock radiator stock cap.. now i have a c&r radiator with high flow cap and it does the same thing but its getting worse.. which i assume means the gasket is getting worse. either way i figure i will mill my head a little get some more compression and throw a new gasket on there.. just a lot of work i didnt feel like doing</TD></TR></TABLE>
i hear ya, i heard from someone on HT, that he used the radiator cap that came with his radiator and teh cap was like 22psi, and it blew his heater core, make sure you system is in good shape to take the 22 psi
Old Jun 15, 2004 | 05:51 PM
yup... already done that.. and ya i am running like 19-21 psi cap.. but it only has a slight chance of blowing the core on an old highmileage car.. mine is still in good shape... not too worried about blowing my core right now...
88HATCH(:
17
Mar 27, 2012 07:04 AM
freshgear
Jul 19, 2009 01:48 PM
chuisek9
May 9, 2008 06:08 AM
iperez
Jan 2, 2004 02:42 AM
spaceman
Sep 24, 2003 06:57 PM
