cooling system
Old Sep 24, 2003 | 11:30 AM
spaceman's Avatar
Default cooling system
after warming up my car and driving around the block,i checked my radiator hoses and the upper one was hot while the lower one was cold...what is that all about?
Old Sep 24, 2003 | 12:14 PM
spaceman's Avatar
Default Re: cooling system (spaceman)
i guess ill go and check it out again..also there was a little steam coming from the header area,would that be my head gasket?
Old Sep 24, 2003 | 12:37 PM
pro1342's Avatar
The thermostat is stuck.....need to replace it.
Old Sep 24, 2003 | 12:46 PM
spaceman's Avatar
Default Re: cooling system (pro1342)
i just put in a new mugen thermostat..could it be anything else?
Old Sep 24, 2003 | 12:47 PM
pro1342's Avatar
Temp may not be high enough to open t-stat yet, or the t-stat is installed wrong or broken.
Old Sep 24, 2003 | 01:40 PM
spaceman's Avatar
i just drove it around again and the temp got to almost halfway and again upper/hot---lower/cold..someone told me to take the radiator cap off and watch to see if water flows when the thermostat opens(if the thermo works)also the top of the rad was hot and the bottom cool i dont know if that matters.could it be the water pump?what do you peeps think?
Old Sep 24, 2003 | 02:53 PM
pro1342's Avatar
It still seems to me that it is a thermostat problem.
Old Sep 24, 2003 | 03:16 PM
spaceman's Avatar
seems like it..does anyone know where the fan switch is on a b16?cuz i noticed my fan hasnt turned on since i dropped in the motor..also does anyone have a pic or diagram on the coolant/water hose routing from the motor to the heater core and back to the motor?cuz i removed the entire ac/heater system(wasnt ever gonna use it)
Old Sep 24, 2003 | 06:57 PM
Sanj's Avatar
Hi there, i would suggest bleeding the cooling system first, possible u have air trapped in the system. Did u bleed the cooling system? Open the bleed until air bubbles stop coming out, or run the car with the rad cap off until the cooling fan cycles. The thermostat is open when the lower rad hose is hot and u can see flow in the radiator. Good Luck, lemme know how it goes!
TurboTeG4
12
Dec 27, 2009 10:20 AM
EM88
Jul 21, 2009 03:12 AM
twenty
Jul 21, 2005 04:32 PM
twenty
Jul 21, 2005 08:36 AM
Gabe_
12
Jun 13, 2003 02:47 AM
