DIY Ground kit for GSR
Old Jun 14, 2004 | 01:43 PM
InfamousGSR's Avatar
Default DIY Ground kit for GSR
Anyone have any picture or instructions on doing up a ground kit. I know there are better ground points and wondering what they were.
The only ones I can think of is the head ground and the tranny ground. What others help out?
I just want something small to do that is cheap. I know its not a big hp gain but it does help a tiny bit. Plus I can get all my cables and all that free.
Old Jun 14, 2004 | 02:16 PM
smurfey002's Avatar
Default Re: DIY Ground kit for GSR (InfamousGSR)
search. this has been covered numberous times.
Old Jun 14, 2004 | 02:17 PM
MajorPayne's Avatar
using the right type of cable is pretty important supposedly, if its not big enough or too big it doesnt help, or so ive heard, ground to throttle body is another good place, and if you have an over abundance of wires do one from ground to IM, ground to vtec solenoid, hmm i cant think of the others, anyways, i made my own ground wires too, so to DIY, f*** over 100 bucks for ground wires, id rather not have them
Old Jun 14, 2004 | 03:13 PM
SamC's Avatar
Default Re: DIY Ground kit for GSR (MajorPayne)
where do you purchase the 4 guage wires? the ones I see in Home depot doesn't look right.
Old Jun 14, 2004 | 03:16 PM
Ti3d in's Avatar
Default Re: DIY Ground kit for GSR (SamC)
Anywhere that sells audio stuff. I saw a veilside ground kit going for 180 dollars!
Old Jun 14, 2004 | 03:17 PM
VTECorona's Avatar
You can use sound system power wire. 8-10 gauge should suffice.
Old Jun 14, 2004 | 03:20 PM
MajorPayne's Avatar
no the wires from home depot work just fine, just find some copper ring terminals for the end, or alum will work too
Old Jun 14, 2004 | 03:40 PM
I searched and nothing came up for me.
Thanks for who gave me useful info.
Keep it coming.
Does the IM already have a ground wire on it?
I just want to replace with better wire and terminals or do I need to make something that all the wires go to the battery terminal.
Ive heard that there are better ground spots then others also. Anyone know what they are talking about?
Old Jun 14, 2004 | 03:57 PM
MajorPayne's Avatar
no there is not a ground wire on the intake manifold already, ive never seen one at least, i didnt run the wires to the neg battery terminal, i ran them to where the neg battery terminal is grounded on the shock tower housing area, theres a black wire, i just put them under the bolt holding the neg battery cable down, which is virtually like putting them directly on the neg batt terminal
lilo_goki
11
Dec 9, 2007 04:52 PM
P_t0wn
Audio / Security / Video
Apr 12, 2004 08:16 AM
CiViC twEaKeR
15
Apr 11, 2004 08:06 AM
BlendedEJ8
Apr 25, 2003 06:40 AM
kay_animation
14
Nov 11, 2002 03:54 PM
