Ground Wire Kit
Re: Ground Wire Kit (CiViC twEaKeR)
Well look at da car and just replace the ones you have.. should be one attached to the tranmission and then one in the front by the head
Re: Ground Wire Kit (BatuKing)
Unless your counting the ground points on the motor for like the starter and other components? there is one right by your Thermostat housing
* B A N N E D *
Re: Ground Wire Kit (sohcvtec1995)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 »</TD></TR><TR><TD CLASS="quote">Just out them somewhere of your likeing. Thats what i did. After i ran out of factory ones to replace.</TD></TR></TABLE>
thats pretty much what i did.
hard to see, but i basicly found a nice spot on the chassis, grounded to the batt, starter, intake mani, valve cover, and i still need one to the alternator. i dunno if it does anything, but ahh well. im moving the one to the valve cover to the block, and yep.
Re: (94greddycivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94greddycivic »</TD></TR><TR><TD CLASS="quote">is there any noticeable gains in a ground wire kit</TD></TR></TABLE>
You'll notice better electrical continuity.
Re: (JRI94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JRI94 »</TD></TR><TR><TD CLASS="quote">
You'll notice better electrical continuity.</TD></TR></TABLE>
yes, your right. I'm thinking he means more in the Hp range, which there is nothing to gain through a grounding system.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CiViC twEaKeR »</TD></TR><TR><TD CLASS="quote">I meant hyper ground wire kit
Ohh! The "hyper" one.
Well why didn't you say so?
This topic has been beaten to death.
Do a search.
Finding the points isn't what people question about it's the way you route it, either daisey chain or seperate points on the chasis.
You got the tranny, the alternator, you got the valve cover, the block and battery terminal, you got your headlamps, you can ground to a chasis bolt like a strut tower bolt, someplace on the firewall; or have them all chain link together leading back to the terminal or have them each have their own point on the bettery terminal; use that head of yours.
Do a search.
BoostedSOHC
90
10-26-2003 11:01 AM
