Buzzing Sounds
Old Apr 11, 2004 | 03:13 PM
P_t0wn's Avatar
Default Buzzing Sounds
Hey,
Whenever i hookup the input / output wires up to my headunit, there is a loud buzzing sounds that changes pitch as the car moves faster. The input/output wires do not even need to be hooked up to the amp and it changes pitches when other eletrical objects are turned on.
Thanks for the Help
~paulll
Old Apr 11, 2004 | 03:26 PM
vigor5spd's Avatar
Default Re: Buzzing Sounds (P_t0wn)
Find a different ground for your headunit.
Old Apr 12, 2004 | 06:51 AM
spark plugs.
Guest
Posts: n/a
Default Re: Buzzing Sounds (vigor5spd)
:::you've got ground noise!::: change your ground and clean the area with some sandpaper before you ground.
Old Apr 12, 2004 | 07:49 AM
AndyGCT's Avatar
ground to the ground, ground ground, ground to the ground, ground ground...
Thats was "Move your Grounds, to the BACK of the Bus" by The Mount That Ground Somewhere Else Connection...
Yeah im a cornball
Old Apr 12, 2004 | 08:16 AM
spark plugs.
Guest
Posts: n/a
Default Re: Buzzing Sounds (AndyGCT)
hahahhaahaha!!!
90Rexx
Aug 25, 2009 12:00 PM
cilvia
Audio / Security / Video
Jan 24, 2007 02:43 PM
hondarsr98
Mar 27, 2006 09:32 PM
