droppin tranny?
right now im changing my clutch and the tranny is on the verge of dropping its jus that i cant take the axles off........all the bolts are off and all i have to do is yank out the axles but those bad boys arent coming off! i all ready tried prying it out wid a screw driver and pulling it at the same time....it worked wid my bois dsm wen we did his tranny but mine is a bitch! any tips on how i can gett this sucka off..........thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeGGY_LS »</TD></TR><TR><TD CLASS="quote">right now im changing my clutch and the tranny is on the verge of dropping its jus that i cant take the axles off........all the bolts are off and all i have to do is yank out the axles but those bad boys arent coming off! i all ready tried prying it out wid a screw driver and pulling it at the same time....it worked wid my bois dsm wen we did his tranny but mine is a bitch! any tips on how i can gett this sucka off..........thanks</TD></TR></TABLE>
i use a fork thing... ball joint puller or ball joint thingy that you use to hammer them out... i used that... works good. you need to pry them out with something
finally got it off! i used a craftsman fat *** screw driver! it was a bitch but went off.....jus dropped the tranny i have a feeling this is gonna be a bitch to put back on after i get the clutch and flywheel on! wish me luck guys....thanks for ur help might turn to u guys again if i run into any problems
im guessing your not doing it on a lift, the only hard part is tring to line the clutch up with the trans you have to hold it up and twist it till it gets all the way in i have dont it in like 1 min or like 30 min sometimes its a real bitch
today i jus realized i broke my axle boot on my driver side. well i didnt break it, but i somehow poked a small hole into it and green sludge started sludging out. it there any way i can fix this without replacing it?
1bar_ek
May 18, 2008 04:44 PM
GayHatch
Apr 2, 2003 08:58 AM
, but where can you get those?
