h22a can be a pain in the... yeah
Old Jun 12, 2004 | 12:48 AM
xcarpetdiemc's Avatar
Default h22a can be a pain in the... yeah
Yeah... I was checking out hasport for engine mounts and raxles but then I got pissed. All the parts go up to 01... what about the 02+ civics. I'm running an 03 and can't find the right axles or mounts. Any ideas? 127 hp is not enough for me ;\ Thanks in advance. later
Old Jun 12, 2004 | 12:50 AM
YEE*MagicEK20kombobomber's Avatar
* B A N N E D *
Default Re: h22a can be a pain in the... yeah (xcarpetdiemc)
h22 in an 02 civic? wtf.... K series man!! K!!!
Old Jun 12, 2004 | 01:34 AM
Default Re: h22a can be a pain in the... yeah (DrunkeNmonk)
Aren't the k20s super expensive? I'm only 19 and poor. With a loan I think I could pull off this h22a swap. Just curious why none of the parts fit damn it. And where to get ones that do Oh, and it's a 03 civic
Old Jun 12, 2004 | 01:38 AM
* B A N N E D *
an h22 in a 03 civic is gonna cost more than a K. i dont think u understand the chassis difference, its not like dropping an h22 in a 92-00 civic. NO ONE (as far as i know) makes an H swap for 03 so ur gonna have to custom EVERYTHING. not worth it
Old Jun 12, 2004 | 01:45 AM
This is gonna be a bitch then. I found ks for like 4-6 grand and that's just for the parts. The install will cost an arm and a leg too. Guess I'm stuck until they come out with something else ;\ Or how about this. Say I keep the stock engine. I get headers, exhaust, intake. That'll take it up a bit. What else could I upgrade on the engine to give more boost? Also, what about turbo and NOS. Would it just be a waste to throw this down on the stock engine... or what horsepower do you think I could pull off if I drop a decent amount into this? Thanks in advance.
Modified by xcarpetdiemc at 11:54 AM 6/12/2004
Old Jun 12, 2004 | 05:59 AM
93acclude's Avatar
An H22 will still be less. K20a cost 5500 dollars for the engine alone, not to mention gettin it put in and then any problems u run into. I say try the H22 swap. get your motor at hmotorsonline.com i got my H22 for $1950! good luck
Old Jun 12, 2004 | 06:22 AM
Default Re: h22a can be a pain in the... yeah (93acclude)
Were you happy with the motor you got from there? Does seem pretty cheap. I wonder if any shops around here will tackle this install since it apparently isn't that easy on an 03 yet. heh, time to call around I guess.
Old Jun 12, 2004 | 06:45 AM
Turbogixxer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93acclude &raquo;</TD></TR><TR><TD CLASS="quote">An H22 will still be less. K20a cost 5500 dollars for the engine alone, not to mention gettin it put in and then any problems u run into. I say try the H22 swap. get your motor at hmotorsonline.com i got my H22 for $1950! good luck</TD></TR></TABLE>
With what mounts is he going to use to put the H22a in there? The motor is cheap but not the labor or fab to do it. If it was me, save for K-series.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xcarpetdiemc &raquo;</TD></TR><TR><TD CLASS="quote">Were you happy with the motor you got from there? Does seem pretty cheap.</TD></TR></TABLE>
I have ordered any swaps from steve with no prob that he did not fix. That price in just for the motor, trans and ECU. You need the cables and shifter and ehat not. The complete swap without LSD will be around $2300.
Old Jun 12, 2004 | 07:02 AM
Sketch_hs's Avatar
don't waste money on bolts on parts
just save up for a GOOD turbo set up or a K swap.
Old Jun 12, 2004 | 07:26 AM
ejONE.mike's Avatar
Default Re: h22a can be a pain in the... yeah (Sketch_hs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sketch_hs &raquo;</TD></TR><TR><TD CLASS="quote">don't waste money on bolts on parts
just save up for a GOOD turbo set up or a K swap.</TD></TR></TABLE>
i agree
Old Jun 12, 2004 | 09:28 AM
jaydogg80's Avatar
Default Re: h22a can be a pain in the... yeah (JayDieM_ej1)
Boost dat beetch!!!
Old Jun 12, 2004 | 09:33 AM
Soccerking3000's Avatar
Default Re: h22a can be a pain in the... yeah (jaydogg80)
ya defiantly go with the k series your engine as it is has the intake out front and trying to switch everything around will just cause major headaches and you will want to throw that h22 out, svae for the k series and dont put anything into the stck engine and then sell it once its out i bet someone just crashed their 02-04 civic and needs an engine
Old Jun 12, 2004 | 09:48 AM
sivik2nr's Avatar
I say, mildly boost it. That will be the best bang for your buck. Then in the future you can always rebuild and boost higher...
Old Jun 12, 2004 | 10:03 AM
trooper0641's Avatar
Default Re: (sivik2nr)
Are the new sohc vtec civics that slow? Cus i beat the **** out of one with 5 people in my hatch! SOHC VS SOHC bwahaha plus 500 lbs extra in my car.
Old Jun 15, 2004 | 02:21 AM
Default Re: (trooper0641)
that make sence cause the new ones are extremely heavy i believe somewhere around 2700-2900 i think correct me if i am wrong so even with the 500 pounds extra yuor car (modded) will beat it just because of the weight
Ek9kidd
Jul 31, 2006 09:42 PM
Plateus
Honda Civic (2001 - 2005)
Jun 12, 2006 10:40 AM
low430
Sep 11, 2005 06:37 PM
vrrodri
30
Apr 4, 2003 06:50 PM
AZHottie
Apr 2, 2003 09:38 PM
