NEED HELP..getting massive amounts of blow by
Old Jun 10, 2004 | 07:36 PM
anothersickhatch's Avatar
Default NEED HELP..getting massive amounts of blow by
just put everything together tonight from changing the head gasket and started my motor up. starts fine but sounds like ****. smoke is coming out of everything, i.e. valve cover, bypass, oil cap, which im guessing is blow by, and it has lost about 60% power while driving. the rings and valve seals should still be good because everything looked good, and i am not throwing ANY codes whatsoever.
i need some help guys...im about to drive my hatch right off a cliff.
Old Jun 10, 2004 | 07:38 PM
Luserkid's Avatar
Default Re: NEED HELP..getting massive amounts of blow by (anothersickhatch)
When you put your belt back on did you make sure that everything was set to TDC?
Old Jun 10, 2004 | 07:47 PM
Default Re: NEED HELP..getting massive amounts of blow by (Luserkid)
yeah, as far as i know i did it correctly...could that be a possible cause? not having the timing right?
Any other possibilities?
Old Jun 10, 2004 | 08:32 PM
come on guys...i need your help..what could be the problem???
Old Jun 10, 2004 | 08:36 PM
ABK's Avatar
ABK
check the compression but it seems like you are leaking pressure somewhere to oil passages.
Old Jun 11, 2004 | 01:51 PM
Default Re: NEED HELP..getting massive amounts of blow by (ABK)
leaking pressure is caused by what? is this like have someone rip-my-motor-apart and fix everything problem or is it something that me and my buddies should be able to fix. Worn piston rings would be the worst case scenario right.
Old Jun 11, 2004 | 02:00 PM
Cnote's Avatar
do leak down. make sure you know where your losing compression at.
via, rings, sleeves, valve guides, inproper head gasket, leaky head gasket,
nato06
Engine Management and Tuning
Jan 30, 2011 11:31 AM
Acuraman918
May 14, 2004 07:14 PM
frog1623
Feb 1, 2004 08:11 PM
KillerBee18
Sep 28, 2003 08:49 AM
bxsi
Jun 11, 2003 06:10 AM
