NEED HELP..getting massive amounts of blow by
just put everything together tonight from changing the head gasket and started my motor up. starts fine but sounds like ****. smoke is coming out of everything, i.e. valve cover, bypass, oil cap, which im guessing is blow by, and it has lost about 60% power while driving. the rings and valve seals should still be good because everything looked good, and i am not throwing ANY codes whatsoever.
i need some help guys...im about to drive my hatch right off a cliff.
Re: NEED HELP..getting massive amounts of blow by (Luserkid)
yeah, as far as i know i did it correctly...could that be a possible cause? not having the timing right?
Any other possibilities?
Re: NEED HELP..getting massive amounts of blow by (anothersickhatch)
come on guys...i need your help..what could be the problem???
check the compression but it seems like you are leaking pressure somewhere to oil passages.
Re: NEED HELP..getting massive amounts of blow by (ABK)
leaking pressure is caused by what? is this like have someone rip-my-motor-apart and fix everything problem or is it something that me and my buddies should be able to fix. Worn piston rings would be the worst case scenario right.
do leak down. make sure you know where your losing compression at.
via, rings, sleeves, valve guides, inproper head gasket, leaky head gasket,
nato06
Engine Management and Tuning
01-30-2011 11:31 AM
bxsi
06-11-2003 06:10 AM
