NEED HELP!!! LS VTEC FULLY BUILT TURBO SETUP!!!
Old Jun 10, 2004 | 01:03 PM
ExplicitSpeed's Avatar
Default NEED HELP!!! LS VTEC FULLY BUILT TURBO SETUP!!!
I need help, I have the following below and I need to know if I should put it a blockguard or will I be fine? or will the blockguard do damage rather then good? Bottom is all assembled. I was told that I might need to insert a block guard? Also do they even make a blockguard for my app. 1.8L with 2.0L sleeves. Will it be okay as it is to make 20 psi and 450 whp max be daily at 12 psi? YES NO? advice help?
91 B18A1 LS bottom
Darton open deck sleeves CRV 2.0L
Crower pro billet rods
JE 20 over 2.OL pistons rings pins
Polished crank
balanced
Got a fully built LS head for sale $1200 obo extras $1450
90 day project coming soon!!!
Modified by ExplicitSpeed at 10:14 PM 6/10/2004
Modified by ExplicitSpeed at 1:06 AM 6/11/2004
Old Jun 10, 2004 | 02:14 PM
B18C1CYA's Avatar
Default Re: NEED HELP!!! LS VTEC FULLY BUILT TURBO SETUP!!! (ExplicitSpeed)
the sleeves look realy thin , who put them in? and what kinda dartons are they?
Old Jun 10, 2004 | 02:34 PM
92HB_HB's Avatar
Default Re: NEED HELP!!! LS VTEC FULLY BUILT TURBO SETUP!!! (B18C1CYA)
my 84 mm bensons look thin like that too..
Old Jun 10, 2004 | 02:49 PM
boosted_dc2's Avatar
Default Re: NEED HELP!!! LS VTEC FULLY BUILT TURBO SETUP!!! (92HB_HB)
that sleeve install dosent look to hot, see the space between the sleeves .
but usually when a block is sleeved, then you dont want to run a block guard.
Landon
Old Jun 10, 2004 | 02:57 PM
CRX T-Si's Avatar
Default Re: NEED HELP!!! LS VTEC FULLY BUILT TURBO SETUP!!! (boosted_dc2)
I agree with boosted_dc2, if your block is already sleeved then you would not want to put a blockguard.
It just does not make any sense ya know.
I am using a blockguard cause I can't afford a sleeved block.
Old Jun 10, 2004 | 03:41 PM
ya there iron ductile I think and the bore is 84.5mm, It was done by a well known shop in San Diego, CA that works on imports so I am sure that they are put in fine. I just needed reinsurance that they will be okay up to 20 psi max without a blockguard added. It's either do or die...
Modified by ExplicitSpeed at 1:07 AM 6/11/2004
Old Jun 10, 2004 | 04:08 PM
yimmy's Avatar
If they are installed correctly then you defiently will not need a blockgaurd.
Old Jun 10, 2004 | 04:10 PM
95GSRTT
Guest
Posts: n/a
450 whp at 12 psi is pretty optimistic. unless of course i completely read that wrong. and you meant 450 at 20 psi lol
Old Jun 10, 2004 | 05:01 PM
Default Re: NEED HELP!!! LS VTEC FULLY BUILT TURBO SETUP!!! (95GSRTT)
besides a block guard will do NOTHING for you for strength. ther are for sleeve movment and stabilization.
Landon
Old Jun 10, 2004 | 05:43 PM
TurboBumblBee's Avatar
no block guards are not needed at all w/ sleeved blocks.. a sleeved block is already stronger then an oem sleeve so your good
Old Jun 10, 2004 | 08:23 PM
99B16Si's Avatar
omg, those are the thinnest sleeves i have ever seen....by far
and are those just the darton replacements because those arent very strong at all
Old Jun 10, 2004 | 08:29 PM
SpdFrk's Avatar
Yeah those look thin. I've never seen darton or any other aftermarket sleeves look that thin.
Old Jun 10, 2004 | 10:17 PM
S2KP's Avatar
looks paper thin, especially inbetween each cylinder
Old Jun 11, 2004 | 12:28 AM
Adi Radoncic's Avatar
On Fire!
Default Re: (Turbo_Siii)
If an unsleeved stock block can take 600whp on a race this this thing will at least do the same if not more. There is no need for a blockguard..
Old Jun 11, 2004 | 08:35 AM
there not that thin, may look it, but there 20 over on CRV and Darton sleeves can take I think as far as 80 over and still have the same power band and strength. AZ came up with a blockguard for me he was kinda like either way about, if you want it to be bullet proof put one in...but i know people who dont and there fine...so i think I will not get the blockguard. I dont plan on goin over 20 psi, so I should be good I am thinkin....
Old Jun 11, 2004 | 08:39 AM
m R g S r's Avatar
If you wanted a cool pattern in the coolant jacket, you should have just gotten some AEBS closed deck sleeves
Old Jun 11, 2004 | 10:46 AM
GEN2TEG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92HB_HB &raquo;</TD></TR><TR><TD CLASS="quote">my 84 mm bensons look thin like that too..</TD></TR></TABLE>
Mine doesn't.
Old Jun 11, 2004 | 11:08 AM
System-7's Avatar
i'm running the same setup except im runnig RS sleeves and they look way wider than those benson's
Old Jun 11, 2004 | 03:54 PM
If I had a choice I would gotten the Darton closed deck, I got the block for cheap so of course I'll take it and make dew.
g0tgot
Oct 9, 2008 04:55 AM
grey16
Oct 12, 2004 04:51 AM
ExplicitSpeed
Jun 10, 2004 03:59 PM
leadfoot78
Dec 9, 2003 03:06 PM
b18bturbo
May 12, 2003 07:32 AM
