Installed Skunk2 Stage1's and timing is off + no gains in power
Old Jun 9, 2004 | 08:56 PM
Wafler's Avatar
Default Installed Skunk2 Stage1's and timing is off + no gains in power
I just installed my new Skunk2 Stage1 cams (with oem sprockets) and I find that my distributor has to be adjusted almost all the way towards the firewall to get the correct timing now. Before, when using my OEM B16A2 cams, the distributor were about at the center of the adjusting holes with correct timing. - I am pretty confident that the tiiming belt is correctly installed... ANY IDEAS?
I am not sure what to expect in terms of power gains but at least -some- on an otherwise stock motor? I experience none, I'm sure...sounds like a bad investment so far...
...and, to advance timing more (for a bit more power) would cause a problem in terms of not having enough space in the adjustment holes at the distributor.
Here is a nice drawing (of the upper adjustment hole at the distributor) of the situation:
Before: Radiator (__O__) Firewall
After: Radiator (____O) Firewall
What the hell am I doing wrong?
I couldn't get a clear answer by searching so I hope someone can give me some hints here...
Old Jun 9, 2004 | 09:53 PM
jamessh1's Avatar
Default Re: Installed Skunk2 Stage1's and timing is off + no gains in power (Wafler)
bump for this, i'm putting stage 1's on stock sprockets also........
Old Jun 10, 2004 | 06:36 AM
DonF's Avatar
Default Re: Installed Skunk2 Stage1's and timing is off + no gains in power (jamessh1)
It sounds like your intake cam is a tooth off (retarded).
Old Jun 10, 2004 | 02:22 PM
AzG35's Avatar
Default Re: Installed Skunk2 Stage1's and timing is off + no gains in power (DonF)
Also sounds to me that your timing belt was incorrectly installed.
Old Jun 10, 2004 | 09:00 PM
BryanPendleton's Avatar
ditto, the t-belt seems to be off. That will kill power too.
exit
Feb 19, 2011 09:30 AM
tobster
Engine Management and Tuning
Aug 20, 2010 05:55 AM
jakscivic
Jun 2, 2010 07:29 PM
john_lauj
Oct 28, 2008 09:33 AM
1SlowSi
May 1, 2004 06:37 AM
