timing is off
Old Oct 22, 2008 | 03:25 PM
john_lauj's Avatar
Default timing is off
hi, i have a b17 and i cant seem to get my timing right. its off by almost a teeth. if you get everything line up, the teeth on the belt and the cams teeth will sit on one another. the only way to get the belt in place is to be off by almost a teeth. i have took it to a couple of shops and they cant seem to find the problem.. please help me with some advise thanks...
Old Oct 22, 2008 | 04:03 PM
racingponys's Avatar
Default Re: timing is off (john_lauj)
How do you know the timing is off?
Does it start and backfire through the intake?
If not, change your plugs, wire, cap, and rotor. Ir thats all good move the distributor and try to re-time the car. If you don't know how, as someone who knows how to help.
Old Oct 22, 2008 | 05:46 PM
sh4mr0ck's Avatar
Are you positive you've reached TDC?
Old Oct 22, 2008 | 06:34 PM
john_lauj's Avatar
Default Re: timing is off (sh4mr0ck)
yes everything has been change but the rotor.. but the thing that catches me is that the car runs but it has a lack of power. around 3.5-5 thousand rpm u can feel the lack of power. the distributor has to be on fully advance for the timing to be close to where it supposed to be.. but still not right on it.
Old Oct 22, 2008 | 06:37 PM
john_lauj's Avatar
oh yea about being sure about the timing, once i got the belt on, i top disc center it and the intake manifold cam is off by almost a teeth.. no back fire or anything. just lack of power..
Old Oct 22, 2008 | 08:12 PM
john_lauj's Avatar
Default Re: timing is off (racingponys)
need help
Old Oct 22, 2008 | 11:54 PM
letsdrive's Avatar
definetly off a tooth. make sure you use a couple allen wrenches or punches to hold the cams at tdc when reinstalling the belt. http://www.team-integra.net/se...=1044
Old Oct 23, 2008 | 03:11 PM
john_lauj's Avatar
Default Re: (letsdrive)
no its not exactly off a tooth just about 3/4 of a teeth only..
Old Oct 23, 2008 | 04:51 PM
hollums2k's Avatar
your off. make sure your crank is set right. when its right its right...not off a teeth.
Old Oct 28, 2008 | 09:19 AM
ok, this might be a stupid question, but did you get the right belt?
If you think you did everything right, make sure there isn't something else wrong with the car.
Hopefully you didn't mess up and bend any valves. Let me know more.
Old Oct 28, 2008 | 09:33 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Be sure you install the belt over each sprocket in the correct order. Always put it around the crank sprocket, hold it tight and put it around the exhaust cam gear sprocket, then around the tensioner and water pump, and then let the belt pull on the tensioner as you put it over the intake sprocket. You could also pull down the tensioner pulley all the way and tighten the bolt before you put the belt on. This will make it a bit easier to get the belt on and around both cam gears.
If you put it over the intake cam gear first before the exhaust cam gear, you will almost certainly be off by a tooth or so, because of slack on the forward side or top of the belt. Slipping it over the exhaust cam first and then the intake cam lets the slack be taken up by the tensioner pulley.
Also remember to go through the proper tensioning sequence. After installing the belt, let the tensioner pulley snug itself on the belt, and tighten the bolt. Rotate the engine 5-6 times, making sure that nothing interferes and that everything stays lined up with each rotation. If not, then you're off. If it stays lined up, then loosen the tensioner pulley bolt, rotate the crank pulley by 3 teeth on the cam gears, and tighten the tensioner pulley bolt to spec. This takes up any remaining slack and prevents the belt from jumping time after you start the engine.
zx92027xz
Aug 11, 2012 06:47 AM
jdmhonda31558
Dec 18, 2010 05:56 PM
DrewDown
Nov 18, 2004 07:05 PM
queez
Apr 14, 2004 01:09 PM
