my piston rings.........
Old Jun 9, 2004 | 07:41 PM
sodacan33's Avatar
Default my piston rings.........
My car has been burning oil for a while and i did a comp. test an ya one was at 80 so time to replace rings. I dont wanna pull the whole motor. But tonight i pulled the head off so im going to drop oil pan an just take the rod bolts out and push the piston up and replace rings is this a good idea? because i am more then half way there? thanks honda tech's!
Old Jun 9, 2004 | 09:36 PM
Ekay Jay's Avatar
Default Re: my piston rings......... (sodacan33)
well if u have already started on it then it dosnt really matter if its a good idea or not. And u have already started it so just finnish it.
Old Jun 9, 2004 | 09:57 PM
ComputerJLT's Avatar
Default Re: my piston rings......... (Bo0sT3d_CrX)
i swapped in new pistons rods and rings with the engine in and the mains still bolted up.
be sure to hone the block and not let any metal shavings get on the crank; and make sure you clean the crank of all dirt and **** and get new bearings and use a lot of moly assembly lube.
Synth124's Avatar
Well while you're at it, just drop your crank and replace all of your bearings too. It's not a lot of work. old ones pop out, new ones go in.
Old Jun 10, 2004 | 12:02 AM
Default Re: my piston rings......... (Synth124)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Synth124 &raquo;</TD></TR><TR><TD CLASS="quote">Well while you're at it, just drop your crank and replace all of your bearings too. It's not a lot of work. old ones pop out, new ones go in.</TD></TR></TABLE>
to drop the crank you have to drop the tranny or at least unbolt it and move it out of the way. not a quick and easy ordeal
Old Jun 10, 2004 | 06:06 AM
crx_88_si's Avatar
Default Re: my piston rings......... (ComputerJLT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ComputerJLT &raquo;</TD></TR><TR><TD CLASS="quote">i swapped in new pistons rods and rings with the engine in and the mains still bolted up.
be sure to hone the block and not let any metal shavings get on the crank; and make sure you clean the crank of all dirt and **** and get new bearings and use a lot of moly assembly lube.</TD></TR></TABLE>
you have to hone the cyl walls for the new rings to seat properly. do WHATEVER u can to keep metal from fallin on the crank! like tape some plastic under the cyl or something!
Old Jun 10, 2004 | 07:10 AM
Full Race A6's Avatar
Default Re: my piston rings......... (crx_88_si)
Ya you can definetely do that. Just make sure that you clean up all the shavings and if you have one of those magnetic oil pan bolts, clean it and check it a few times.
Good luck
Paul Kane
K Series
Jun 8, 2015 05:49 PM
eg_gsr11
Mar 5, 2006 04:27 PM
vw-honda-hatches
Apr 20, 2003 12:42 AM
Type-Rare#1248
Mar 12, 2003 11:10 AM
ScrapinSi
Jul 18, 2002 03:09 PM
