are all the distributor bolts needed?
My swap came with a broken cam holder on the exhaust side. b18c1.
The came is still held down by the holder but the top part which has a hole for the bolt to go into the distributor got broken off. Now the distributor is held down by only two bolts rather than three. Is this going to be a problem?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StockEG9 »</TD></TR><TR><TD CLASS="quote">My swap came with a broken cam holder on the exhaust side. b18c1.
The came is still held down by the holder but the top part which has a hole for the bolt to go into the distributor got broken off. Now the distributor is held down by only two bolts rather than three. Is this going to be a problem?</TD></TR></TABLE>
It will be fine to drive around in. Replace it when you can (as soon as possible).
