smog question???
Old Jun 8, 2004 | 01:16 PM
mini-v-si's Avatar
Default smog question???
I am due for smog soon, my mods are
skunk2 stage 1 cams
skunk2 cam gear
vortech fpr
dc headers/exhaust
p28 skunk2 chips
running on b16 tranny.
what do I have to change to pass smog??? I pretty much have all the stock parts, but don't have the cams, will the skunk 2 stage one pass??? give me any other advice as to remove???? thanks
Old Jun 8, 2004 | 01:41 PM
posjr's Avatar
Default Re: smog question??? (94tegGSR)
If you find someone that will pass it for you hit me up because i'm 1 year past due and now dropping the h22 so not good....
Old Jun 8, 2004 | 03:54 PM
94gsr4dr's Avatar
Default Re: smog question??? (posjr)
Might be tough in cali, but i am facing a similar problem. MD has pretty strict emissions (not like cali), and i am not liking my chances of passing.
Old Jun 8, 2004 | 05:49 PM
Pretegra's Avatar
see if you can find someone who will pass you,or try to find someone who decked out there motor and ask them how did they pass.My friends paid someone to pass emission you know on the down low.
Old Jun 9, 2004 | 06:37 AM
andrew dc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94tegGSR &raquo;</TD></TR><TR><TD CLASS="quote">I am due for smog soon, my mods are
skunk2 stage 1 cams
skunk2 cam gear
vortech fpr
dc headers/exhaust
p28 skunk2 chips
what do I have to change to pass smog??? I pretty much have all the stock parts, but don't have the cams, will the skunk 2 stage one pass??? give me any other advice as to remove???? thanks</TD></TR></TABLE>
are the cams tuned?
the fpr my not pass visual..
header is fine as long as the EO number/carb number is on there
use a stock ecu, chipped ecus run richer
tranny doesnt matter
Old Jun 9, 2004 | 09:23 AM
mini-v-si's Avatar
Default Re: smog question??? (andrew ef)
some people say that stage 1 will pass smog but not too sure. what do you guys thing??? I still have the stock cam gear. fpr, header exhaust, ecu, but I'm just afraid of the cams and working on the cams.
Main concern is have anyone went through smog with a stage 1 cams???
Old Jun 9, 2004 | 09:51 AM
iH8RICERZ's Avatar
you'll pass fine w/ the skunk2 stage 1's..........the thing thats going to make you fail is probably the fpr, and for damn sure the chipped p28 w/ the skunk2 program!!! get a stock gsr ecu, tune your fpr so its pretty much back to stock, and then you should be fine if your stock cat is still in ok condition!
Old Jun 9, 2004 | 10:49 AM
mini-v-si's Avatar
Default Re: smog question??? (iH8RICERZ)
what about the cam gears, just so that I don't go through so many trouble???
Old Jun 9, 2004 | 10:54 AM
iH8RICERZ's Avatar
if you can, set the cam gears back to 0 on both intake and exhaust side....thats if they are tuned.....also, check your timing!
Old Jun 9, 2004 | 11:03 AM
mini-v-si's Avatar
so your saying that I can have the cam gears in but just have it back to specs???
Old Jun 9, 2004 | 12:43 PM
posjr's Avatar
I had a fpr and cam gears and it wouldnt pass visaul.
Old Jun 9, 2004 | 01:32 PM
mini-v-si's Avatar
so really if I can set cam gears back to specs and timing, I stil wouldnt pass visual, am I correct???
Old Jun 9, 2004 | 04:43 PM
andrew dc's Avatar
do you have a full valve cover and the plastic cover? that should help them NOT be able to see the cam gears
Old Jun 10, 2004 | 12:19 AM
mini-v-si's Avatar
oh **** yeah, thats a good idea but just got to find the top piece.
Old Jun 17, 2004 | 12:20 AM
mini-v-si's Avatar
alright so far the car runs weaker with the stock Fuel regulator pressure. Can I still keep the chipped p.28 on the car. any last suggestion on removal of my mods before I take my car in for a smog???
Old Jun 17, 2004 | 12:26 AM
NoBottleJustThrottle's Avatar
I think the real question is where you go. Some SMOG guys are just nicer than others. If you goto a ghetto part of town, to some dumpy looking run down place that just so happens to run SMOG checks, you will probably be fine with what you have. If you goto the nice part of town, where SMOG checks are a regular thing for that particular shop, you are going to have problems. Thats just my $0.02 though.
Good luck.
Old Jun 17, 2004 | 12:29 AM
mini-v-si's Avatar
Default Re: smog question??? (NoBottleJustThrottle)
hey thanks for the heads up. That's what I was thinking too.
Old Jun 20, 2004 | 05:28 PM
mini-v-si's Avatar
I totally forgot to mention one thing I also have a 68mm holley throttle body, will that be a problem with smog.
acura_b18c1
Apr 16, 2006 08:03 AM
usmcsoldriver
22
Feb 26, 2006 02:22 PM
is3oo
Mar 2, 2005 01:05 PM
TypeRPaul
Oct 2, 2004 01:38 AM
jeffk182
May 12, 2004 01:43 PM
