LCAs: ITR vs DC/EG
Old Jun 8, 2004 | 05:28 AM
Mike_C's Avatar
Default LCAs: ITR vs DC/EG
I plan on getting a rear sway and some pimpy new coilovers for my EG so I picked up some ITR LCAs this past week. Problem is, finding a nice set (1500+ new) of used coilovers that mate to the ITR rears is proving difficult. Is there any disadvantage to dumping the ITR LCAs and just going with something that is compatible with more hardware (has holes for sway but takes EG or DC [not R] shocks)? I'd have to think there was some reason for Honda engineers to make the ITR rear shock mount different, I just don't know why...
edit: Added "used."
Modified by MichaelJComputer at 11:41 AM 6/8/2004
Old Jun 8, 2004 | 07:33 AM
Mike_C's Avatar
Anyone?
Old Jun 8, 2004 | 08:21 AM
dfoxengr's Avatar
Default Re: (MichaelJComputer)
i dont think theres a disadvantage i mean theyre both thick pieces of steel. are you asking about flexing and whatnot?
why not try some of these blingbling SRR or 'megan' LCAs. theyre lighter and supposedly better than all stock ones.
plus you get the hot purple with srr.
a friend got the megan ones off ebay for like 90 bux too
Old Jun 8, 2004 | 09:08 AM
Mike_C's Avatar
No I'm not talking about flexing or anything (unless that is a factor with stock lcas). Just wondering if anyone had any insight on why Jonda engineers chose to make the ITR pieces differ from all the others.
Also, no point in burning $100 for "bling-bling" LCAs when I can pick up a set of stockers w/ stock bushings (I've heard horror stories of Megans and SRR bushings).
Old Jun 8, 2004 | 09:27 AM
dfoxengr's Avatar
they have bad bushings really? i hate the stock ones since they always freeze.
Old Jun 8, 2004 | 10:08 AM
Mike_C's Avatar
The bushings aren't bad per se, but I have seen a few wear/tear prematurely. Armed with my trust bottle of anti-seize there is no stock LCA that scares me.
Old Jun 9, 2004 | 12:28 PM
AcidGord's Avatar
The way the rear struts hook into ITR LCAs gives a bit of passive rear steering. There was a bunch of posts about it last fall in the Road Race/Autocross forums. Older CRXes had a similar setup.
Old Jun 9, 2004 | 12:45 PM
Mike_C's Avatar
That was the kind of info I was looking for!
Thanks!
Old Jun 9, 2004 | 04:33 PM
Katman's Avatar
just some fyi..
ITRS and CRX's aren't the only vehicles that came with the ITR style rear LCA or 'box style' rr lca. Pretty much, all JDM EF+EG civics & DA+DC integra's all came equipped with these rear LCA's. Why Honda of America US only chose the ITR & CRX to sport these LCA's is a mystery, but for the US ITR I'm betting they wanted to keep the Japanese Type-R theme to the car as much as possible (minus, not changing the front end).
You can easily find $1500+ suspension to fit into your ITR LCA's. Tein, Apexi, JIC, etc., all make sus that will fit into your LCA's. You just need to order Integra Type-R specific suspension for your car and you can put those LCA's to use.
Old Jun 9, 2004 | 05:03 PM
AcidGord's Avatar
Default Re: (Katman)
True enough, my winter suspension is from a JDM Civic SiR-II which bolts right into my ITR lower control arms. Go figure.
Old Jun 9, 2004 | 08:40 PM
navin's Avatar
christ...
do I have to take you to Japan Star myself...
LoNgHoRn
Apr 25, 2007 11:52 PM
spoolinegsr
Sep 3, 2006 12:46 PM
skribblah
Jul 26, 2003 11:14 AM
keithdphan
May 1, 2003 04:13 PM
