Car Won't Start HELP!!!
Old Jun 8, 2004 | 12:15 AM
8ball629's Avatar
Default Car Won't Start HELP!!!
I just got done with my b16a SiR 1 engine swap and of course there are problems . Anyway, when I turn the key nothing happens. There is no sound from the engine bay, there is no fuel pump sound and I get a solid engine code. I don't know what it means when the ECU light doesn't go off but thats the most recent code and the only code that has stayed after a few turns of the key. But like I said, no sound from the starter, no click. Nothing. All of the electrical things work inside the car and headlights, turn signals, and taillights also work. Its just when I put the clutch it and turn the key, nothing ****** happens as if the clutch weren't in. And the pedal does hit the switch that detects the clutch pedal in so I don't know whats goin on. This is an 89 CRX Si with b16a SiR1 and PW0 ECU. I bought the HASport harness that adds those 4 plugs and installed it correctly by the way.
Any suggestions are appreciated. Let me know what you guys think is going on.
Thanks in advance,
Brian "8ball"
Old Jun 8, 2004 | 04:37 AM
crx_88_si's Avatar
check the thermostat ground.
Old Jun 17, 2004 | 11:33 AM
oddcivic's Avatar
Default Re: (crx_88_si)
i got the same problem... never found out whats was the problem
gustafse
Nov 27, 2011 04:55 PM
johnwohl
17
Apr 6, 2009 05:58 AM
Coelacanth
Sep 11, 2004 11:37 AM
detailer67
Apr 22, 2004 08:10 PM
turboxsi
Oct 17, 2003 08:21 PM
