problem with cam install
Old Jun 6, 2004 | 08:53 PM
princeallure's Avatar
New User
Default problem with cam install
Heres the scoop.. i bought a set of used toda b and vavle springs..
installed it and turned it manual on the crank.. the retainer was to be dead tight so little free play on the belt.... everything seem ok. so fired up the car.. the valves are clicking very loud.. almost like gatling gun.. have a buddy that has a simmilar set up his vavletrain sounds fine just a bit louder then stock.. but on my car the sounds are much much louder.. anyone shed some light? and possible solutions?
Old Jun 6, 2004 | 09:24 PM
egmaster's Avatar
Default Re: problem with cam install (princeallure)
sounds like you just need to adjust your valves
Old Jun 6, 2004 | 09:48 PM
2000ekhatch's Avatar
Default Re: problem with cam install (egmaster)
valve lash, or lmd's are bad.
Old Jun 7, 2004 | 12:48 AM
New User
Default Re: problem with cam install (2000ekhatch)
vavle lash is correct.. how do i test for lma goin bad?
Old Jun 7, 2004 | 01:59 AM
JDMotive's Avatar
to test the lma's you have to take them out of the head and test them on a spring pressure tester(i forget how much pressure they are supposed to have though)..but its most likely not that.I had a similar problem,and it turned out to be wrong valve lash settings.I set them to factory settings(skunk2 stage 2 cams) but adjusted them so the feeler would go in easily,which is why they were too loose...just in case,here's the valve settings.. .007 intake and .008 exhaust.
Old Jun 7, 2004 | 08:39 AM
New User
Default Re: problem with cam install (JDMotive)
yah i tried dat setting the valves lash to dat im goin to double check everything
Old Jun 7, 2004 | 11:17 PM
New User
so anyhow did a comp test today and got 230psi consistently on 4 cylinders im thinking the valvesprings are the cauze so intalling a set of skunk2 in and goin to try to fire it up tomorow
Old Oct 8, 2004 | 10:20 AM
Davep's Avatar
Anyone else have this problem after installing camshafts?
I'm having the same problem with loud ticking coming from the valvetrain. I'm using Buddy Club spec 3+ cams, ITR valvetrain, crower ti retainers, and valve lash set to .007/.008. The damn thing is loud as hell.
Old Oct 8, 2004 | 10:38 AM
hybrid_vtec's Avatar
Default Re: problem with cam install (Davep)
Regardless what you say, I think it is the Valve Lash and I think you should double check it!
Old Oct 8, 2004 | 10:40 AM
Davep's Avatar
Default Re: problem with cam install (hybrid_vtec)
ok. i've adjusted it twice to try two different specs but i'll check it again.
Old Oct 8, 2004 | 02:39 PM
colt45.5's Avatar
pee, are you sure stock springs are sufficient for that setup?
I dont know what it could be. Id say valve lash also. What are you running the intake and exhaust lash at?
boosted94gsr
Jun 14, 2014 10:13 PM
pchan
32
Jul 18, 2007 10:46 PM
princeallure
Jun 6, 2004 05:53 PM
lilredhatch
10
Feb 8, 2004 05:59 AM
madslackin
Jan 20, 2002 04:16 PM
