problem with cam install
Old Jun 5, 2004 | 04:52 PM
princeallure's Avatar
New User
Default problem with cam install
Heres the scoop.. i bought a set of used toda b and vavle springs..
installed it and turned it manual on the crank.. the retainer was to be dead tight so no free play on the belt.... everything seem ok. so fired up the car.. the valves are clicking very loud.. almost like gatling gun.. have a buddy that has a simmilar set up his vavletrain sounds find just a bit louder then stock.. but on my car the sounds are much much louder.. anyone shed some light? and possible solutions?
Old Jun 5, 2004 | 05:01 PM
92TypeR's Avatar
FSAE
Default Re: problem with cam install (princeallure)
What did you set the valve lash to?
Old Jun 5, 2004 | 05:25 PM
New User
Default Re: problem with cam install (92TypeR)
.2mm
Old Jun 5, 2004 | 06:03 PM
jiahanhao's Avatar
you did use the angled feeler gauge when you set the lash right?
(don't mean to imply anything... so don't take this the wrong way)
Old Jun 5, 2004 | 11:24 PM
pbizzlegsr's Avatar
for some reason mine clicks around the cam gear area..sounds exactly like how you described..after cam gear install also..is your valve cover cut..mine is and i was told it should be louder now that it is..but the clicking it quite loud
Old Jun 6, 2004 | 02:23 AM
New User
Default Re: problem with cam install (jiahanhao)
yes i did use the angled feeler gauge
Old Jun 6, 2004 | 11:27 AM
New User
one more thing how tight the timing belt retainer should be? cuz if I tighten to oem spec its ok but when i turn one rev the cams gears kinda jumps... my friend tells me they should be tighten so much so theres no free play on the timing belt
Old Jun 6, 2004 | 05:53 PM
92TypeR's Avatar
FSAE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by princeallure &raquo;</TD></TR><TR><TD CLASS="quote">one more thing how tight the timing belt retainer should be? cuz if I tighten to oem spec its ok but when i turn one rev the cams gears kinda jumps... my friend tells me they should be tighten so much so theres no free play on the timing belt</TD></TR></TABLE>
There should be about 1/2" to 1" of travel on the long side (front of engine).
mattie_96
Jun 18, 2006 10:28 PM
princeallure
10
Oct 8, 2004 02:39 PM
simplypinoyy
Sep 25, 2004 07:28 PM
agent marlon
Nov 19, 2002 07:58 PM
