do i need any upgrade my valvetrain? when i put light flywheel
i have 00GSR and bone stock...iam trying to put light flywheel..( Fidanza Aluminum Flywheel)...so my question is do i need any upgrade engine?? like valvetrain?
no unless you plan on reving higher. They are seperate and have nothing to do with each other. If your gonna do a flywheel then you should prob do the clutch, throwout bearing also. prob save time in the future.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoonKillerB »</TD></TR><TR><TD CLASS="quote">oh is using stage1 clutch ok?</TD></TR></TABLE>
Stage 1 is simply a number system put out by a certain manufacturer. It doesn't really mean anything. "Stage One" with one company might equal a "Stage 3" in another.
Getting a lighter flywheel doesn't really affect (TOO MUCH) what clutch you should get. Then again, it all depends on your application. You probably don't want a dual plate pressure plate with a 3 puck disc on your Fidanza unless you like pieces of your flywheel piercing your car and person
.....but then again, you might need it in your application.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoonKillerB »</TD></TR><TR><TD CLASS="quote">all my plan is just intake and flywheel and maybe skunk MF...thats about it..nothing really tune up....</TD></TR></TABLE>
LOL 3 completely unrelated parts... which u might not see significant gains w/ anything...
edit: sorta unrelated.
civichatcheg6
Transmission & Drivetrain
Feb 14, 2010 10:01 AM
