Life of a clutchmasters clutch?
New User
I have a stage 4 clutchmasters disk with a stage 3 pressure plate and a type R flywheel. When i pulled my engine to rebuild it I noticed the clutch is about at the rivets. Ive only had this clutch on for 7500 miles and boosted from 6-10psi. How long does one of these clutches last, I would have thought it would last longer than this. Also my flywheel and PP have worn with a taper with more ware to the outside. Is this normal for this clutch?
Re: Life of a clutchmasters clutch? (B20LS-T)
I have the same setup on my lude except i have a fidanzy flywheel. I pulled my motor with about 4k on the setup and it still looked new, the only problems i have had are the springs rattling.
New User
Re: Life of a clutchmasters clutch? (autoEXturbo)
Im thinking it might be becuase im using a stage 3 PP and it doesnt have enough pressure to hold the disc to the flywheel, could that be it? what pressure plate are you guys using?
Thee_Antic
10-25-2011 02:01 AM
lkailburn
44
09-28-2004 12:02 PM
