vtec not coming on when it should.....
i have a kenji chipped p28 ecu. the vtec crossover is set at 5300, but it doesn't hit vtec until 5800. i don't think its the chip. he sent me 3 chips already and they all do the same thing. why would this be happening? i checked all my wires from my tach today and they all have good connections. its an autometer 5" tach with shiftlight.
would needing a serious valve job cause vtec to come on later?
thanks
thanks
hmmmmm.....what would cause the tach to be off? is the tach bad?
then damn, if the tach is off, then i could really be at 5300 when the tach reads 5800? that would mean i'm shifting earlier than i should.
my car idles fine though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaeg8 »</TD></TR><TR><TD CLASS="quote">hmmmmm.....what would cause the tach to be off? is the tach bad?
.</TD></TR></TABLE>
Is the tach OEM? There you go.
.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">
Is the tach OEM? There you go. </TD></TR></TABLE>
Read son.
Its an autometer 5" tach with shiftlight</TD></TR></TABLE>
Read son.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">
Read son.
Eh ::shurgs::
Read son.
Eh ::shurgs::
Read son.
haha dustin
Read son.
haha dustin
How do you know when its hitting VTEC? The only way to really know is to have a light hooked up to the VTEC signal wire and see when the ecu sends the signal..
Just because you dont feel or hear it right away doesn't mean its not kicking in..
i tried that today. the revlimit should be set at 8500, but i went up to 8800, by accident. i don't even want to try to go any higher. with the redline at 8500, where it should be, i still shift at 8k. i don't want to see how high it will go cause my motor has all stock internals.
96hatchBoy
Jun 8, 2013 02:31 PM
SleepnCiViC
14
Jan 16, 2004 05:46 PM
CimorelliCRX
Mar 18, 2003 07:20 AM
