Brake Problem
Old Jun 6, 2004 | 09:52 AM
Bizarre's Avatar
Default Brake Problem
Well, I'm having some serious braking problems. I've done quite a few brake jobs and never really had this problem before. Anyways, I changed all my pads, rear calipers, turned my rotors also flushed out my brake fluid. When I brake the pedal basically goes all the way to the floor. There is no way I'd be able to make an emergency stop. When bleeding, I accidentally forgot to check the MC level, and let it get a little low. I'm not sure if I let any air in, but just incase I've bled a total of one liter of brake fluid. There's no air coming out of the lines when bleeding, so I have no idea what the problem can be. I'm thinking I'm going to have to bleed the system first at the MC. What do you think? Car is a 90 Integra.
Old Jun 6, 2004 | 02:08 PM
SiR Inspired ED7's Avatar
Default Re: Brake Problem (Bizarre)
hey there what i would do is bleed your brakes again. get someone to press on the brake inside the car and u do the the rest out side...know what i mean? well i hope that works im just trying to help...
My Nitto Site:
http://www.dusktwodawn.com
Rap Music:
http://www.soundclick.com/bands/1/13ounce.htm
Old Jun 6, 2004 | 02:36 PM
IVI's Avatar
IVI
how did you bleed the brakes?
theres a certain sequence to bleed them from.
if your certain you bled them properly then it sounds like you have a problem with your master.
bench bleed it and check.
Old Jun 6, 2004 | 03:53 PM
Bizarre's Avatar
Default Re: Brake Problem (IVI)
Alright. Well I'm almost sure I messed up my master cylinder. I did the bleeding in sequence according to the Helms manual. Were I think I ran into the problem is, when I bled the system I let the brake pedal hit the ground a couple of times. That combined with the low fluid could have sucked in some dirt(Sitting in the bottom of the MC) in my MC. I have a ITR master cylinder sitting in my basement. Gonna try putting that on with a nice bench bleed. Hopefully it will solve my problem. Thanks guys for your input/help, I'll keep you updated.
Old Feb 5, 2005 | 04:42 PM
Bizarre's Avatar
Bump, still have the same problem. Master cylinder has also been replaced and bench bled, as well as all four corners in sequence were bench bled. Could the pedal hitting the floor somehow have messed up my proportioning valve?
xkrazyxjbrkerx75
13
Jul 16, 2011 04:27 PM
bonspeed
Suspension & Brakes
Dec 10, 2009 01:10 AM
gh0st32
May 15, 2005 08:36 AM
viperguy
Jul 29, 2003 06:57 PM
sacredc0w69
Apr 29, 2003 11:05 AM
