b18c5 in a ek
Old Jun 5, 2004 | 06:59 PM
Orangecivic251's Avatar
Default b18c5 in a ek
ok guys let me start by saying i have no idea i have checked the main relays all the grounds everything but this mottor will not even turn and i have no idea. worked and just quit!!!!!!!
Old Jun 5, 2004 | 07:06 PM
SprayinCX's Avatar
Default Re: b18c5 in a ek (OrangeCiviC251)
is your battery good? does your lights on the dash come on? if yes does the strater solenoid click when trying to crank it?
Old Jun 5, 2004 | 08:04 PM
dunkd's Avatar
starter wires?
Old Jun 6, 2004 | 10:54 AM
Default Re: (dunkd)
see that's what i thought and i checked all of that stuff motor now cranks but won't start and i keep blowing the fuse FI E/M. any i dea why it's doing this. the starter is good though and battery is on charger now but i knoiw that's not the reason
Old Jun 6, 2004 | 01:41 PM
SprayinCX's Avatar
Default Re: (OrangeCiviC251)
if it keeps blowing fuses then you need to trace the wire back and look for bare wire touch metal. cause if the wire is grounded out it will do this. and also check for the fuse rating, cause to small of a fuse will do the same thing.
Old Jun 6, 2004 | 02:00 PM
ATS*Mark's Avatar
OG triple OG
Default Re: (SprayinCX)
ya youve got a FI wire problem , plug hooked up backwards perhaps . or somthings grounded that shouldnt be.
Old Jun 16, 2004 | 02:00 PM
Default Re: (Hella_JDM)
thanx guys still not sure why
Old Jun 16, 2004 | 02:11 PM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OrangeCiviC251 &raquo;</TD></TR><TR><TD CLASS="quote">see that's what i thought and i checked all of that stuff motor now cranks but won't start and i keep blowing the fuse FI E/M. any i dea why it's doing this. the starter is good though and battery is on charger now but i knoiw that's not the reason</TD></TR></TABLE>
I would start from scratch of where you first started -- the wiring of course.
You have a short somewhere. Those are a pain in the ***.
Old Jun 16, 2004 | 02:12 PM
Deemeetree's Avatar
Electrician
Cheese and Rice bro. Your car has way too many problems to begin with. Read a few posts already on Page 1 with your probs. If I were you, go back and do the wiring again.
Old Jun 16, 2004 | 03:10 PM
DeLSoLo's Avatar
troubleshooting is a B****!!!!
Old Jun 16, 2004 | 03:11 PM
Default Re: (DeLSoLo)
i got it figured out!
woo hoo 100 posts!!!!!!
Old Jun 16, 2004 | 03:33 PM
Urban Camo's Avatar
some wire is grounding out your starter and blowing a fuse
evilho75
May 13, 2012 01:35 PM
Fo-Do Fanatic
Mar 3, 2011 12:29 AM
1Bluegsr
Oct 3, 2007 01:47 PM
ILIKEJDMX999
Apr 19, 2006 06:33 AM
ppfalcon
Dec 11, 2005 01:14 PM
