b18c5 in a ek
b18c5 in a ek
ok guys let me start by saying i have no idea i have checked the main relays all the grounds everything but this mottor will not even turn and i have no idea. worked and just quit!!!!!!!
Re: (dunkd)
see that's what i thought and i checked all of that stuff motor now cranks but won't start and i keep blowing the fuse FI E/M. any i dea why it's doing this. the starter is good though and battery is on charger now but i knoiw that's not the reason
Re: (OrangeCiviC251)
if it keeps blowing fuses then you need to trace the wire back and look for bare wire touch metal. cause if the wire is grounded out it will do this. and also check for the fuse rating, cause to small of a fuse will do the same thing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OrangeCiviC251 »</TD></TR><TR><TD CLASS="quote">see that's what i thought and i checked all of that stuff motor now cranks but won't start and i keep blowing the fuse FI E/M. any i dea why it's doing this. the starter is good though and battery is on charger now but i knoiw that's not the reason</TD></TR></TABLE>
I would start from scratch of where you first started -- the wiring of course.
You have a short somewhere. Those are a pain in the ***.
Electrician
Cheese and Rice bro. Your car has way too many problems to begin with. Read a few posts already on Page 1 with your probs. If I were you, go back and do the wiring again.
evilho75
05-13-2012 01:35 PM
Fo-Do Fanatic
03-03-2011 12:29 AM
ppfalcon
12-11-2005 01:14 PM
