car wont start after battery move to back..help
Old 06-22-2011, 06:10 PM
evilho75's Avatar
Icon2 car wont start after battery move to back..help
92eg vtech....I. just finish doing a wire tuck on my civic, and move battery to back of the car and move fuse box inside the cabin,now it won't start, no lights, dahsboard no lights.
I check with metter and have voltage on the starter, fusebox, alternator, but no power anyware??????
I ran a 2g wire from hatch to starter
From starter 10g to fuse box
And reconect alternator to fusebox.
And 10g from fusebox to ground.
Anybod! Please help??????
Old 06-22-2011, 06:41 PM
Former User's Avatar
Default Re: car wont start after battery move to back..help
Check continuity to body ground from the battery ground post.
Old 06-25-2011, 09:08 AM
Sp00n2nr's Avatar
Do you have a good connection between the starter and the fuse box? Should be a thick white wire if I'm not mistaken.
Old 06-27-2011, 08:07 AM
evilho75's Avatar
I have a 10g wire btween starter and fuse box, is the wire coming from alternator conects to + or - on fuse box?
Old 07-01-2011, 04:04 PM
Sp00n2nr's Avatar
I'm almost sure it's the positive. On the fuse box you will have 2 thick wires going into it which bolt down. Closest to the fuses is the wire that goes to the positive side of the battery and then furthest away from the fuses is your alt wire. I would also check the 80 amp fuse to see if it's still good. Hope that helps
Old 05-13-2012, 01:09 PM
evilho75's Avatar
thanks for all the help,,i had inverted wires my friend come tru and help out
Old 05-13-2012, 01:35 PM
The Grumpiest
grumblemarc's Avatar
Which wires? I'm going to assume we aren't talking about the two battery wires.
DialedLife
03-31-2019 12:07 PM
DailyDriven259
05-11-2012 11:31 AM
notmightydx
Engine Management and Tuning
10-21-2008 08:00 AM
jimihendrixbro
11-23-2007 10:39 PM
philkehn
21
07-05-2006 08:29 PM
Quick Reply: car wont start after battery move to back..help
