Setting idle with a digital multimeter
Old Jun 4, 2004 | 09:03 AM
mct121's Avatar
Default Setting idle with a digital multimeter
I recently bought a good digital multimeter for non-automotive applications. It, obviously, does not have an RPM setting on it. I was wondering if there was a way that I could use it to check my idle or am I forced to pick up another multimeter with the proper calibration on it?
Thanks in advance....
Old Jun 5, 2004 | 05:12 AM
mct121's Avatar
Default Re: Setting idle with a digital multimeter (mct121)
Nobody knows or nobody likes me because I am new?
Old Jun 5, 2004 | 08:25 AM
integra-modder's Avatar
what are you trying to do exactly? the reason the automotive ones can do rpm is because the dmm reads the number of pulses in the tach signal
Old Jun 5, 2004 | 03:41 PM
DonF's Avatar
Both.
Old Jun 6, 2004 | 06:09 AM
mct121's Avatar
Default Re: Setting idle with a digital multimeter (integra-modder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra-modder &raquo;</TD></TR><TR><TD CLASS="quote">the dmm reads the number of pulses in the tach signal</TD></TR></TABLE>
That answers the question that I *should* have asked. Thanks for the help.
Old Jun 7, 2004 | 05:07 AM
JimBlake's Avatar
Some DMM's (like my Fluke 179) can measure frequency in Hz. I haven't tried it yet, but I suppose there's 2 pulses per revolution, so you multiply Hz x 30 to get RPM. (3 pulses per revolution for a V6)
Old Jun 7, 2004 | 05:51 AM
Default Re: Setting idle with a digital multimeter (JimBlake)
Im sure there is a way to do it. On the older hondas the tach wire from the distributor sent out a pulse when the cam and crank signals are synced, which can only happen at 1 time during a rev. The newer one take their tach reading directly from the ecu, which essential just mirrors half of the coil output.
Old Jun 7, 2004 | 12:17 PM
mct121's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">I haven't tried it yet, but I suppose there's 2 pulses per revolution, so you multiply Hz x 30 to get RPM. (3 pulses per revolution for a V6)
I think CKP sensor emits four pulses for each rotation of the camshaft from my D16Y7. The crankshaft rotates at twice the speed of the camshaft.
So if I take a frequency measurement by backprobing the CKP connector at the distributor and divide by four that is the camshaft rotational speed in Hz. Multiply that by two to get the crankshaft rotational speed. Also a comversions from Hz to RPM since my meter reads in Hz. Therefore,
(Frequency from CKP in Hz) * 30 = (Crankshaft rotational speed in RPM)
Did I do that right?
Thanks again for the input.
Old Jun 7, 2004 | 12:50 PM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mct121 &raquo;</TD></TR><TR><TD CLASS="quote">I think CKP sensor emits four pulses for each rotation of the camshaft from my D16Y7.</TD></TR></TABLE>As long as that's true, you're right. Check it against your tach at a few different speeds. You use the DMM at idle because your dashboard tach isn't very accurate down there. But it won't be off by a factor of 2...
Even though the tach signal is generated by the ECM, I figured it had one pulse per spark, so 2 pulses per crank revolution. Pretty much the same as what you said.
But if it's like integra-modder says (1 pulse per crank rev), then take Hz x 60 = RPM.
Old Jun 7, 2004 | 07:18 PM
mct121's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">Check it against your tach at a few different speeds.</TD></TR></TABLE>
That is what I intended to do. Thanks for the help.
Old Jun 8, 2004 | 09:43 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">But if it's like integra-modder says (1 pulse per crank rev), then take Hz x 60 = RPM.
Sorry, didnt mean to confuse you. The one pulse occurs only when the Cam/Crank sensors are synced. You are completely, theoreticaclly, correct about the fact that the coil output gets 2 pulses for a complete revolution. Then again, this is all theoretical until someone tests it.
Old Jun 11, 2004 | 10:35 AM
mct121's Avatar
I still have not had a chance to hook it up. (sorry, been busy) But I did find this in a search:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mct121 &raquo;</TD></TR><TR><TD CLASS="quote">I think CKP sensor emits four pulses for each rotation of the camshaft...</TD></TR></TABLE>
According to this thread the CKP emits 24 pulses on my ODB2 engine. That is going to change my math a little bit.
Old Jun 13, 2004 | 06:53 PM
mct121's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra-modder &raquo;</TD></TR><TR><TD CLASS="quote">Then again, this is all theoretical until someone tests it.</TD></TR></TABLE>
Just to close this out, I did give it a try. I found the external tach connector (I didn't even realize that it existed when I started this thread, pardon my ignorance) and connected my DMM to it with the other lead to the body. The freq that my DMM showed was off of the dash tach by a factor of thirty. That means that there are two pulses per crank revolution on that line.
Again, thanks for the help. I am still learning here.
sniperslayer
Apr 26, 2020 05:36 PM
Civicman86
Jul 10, 2007 02:40 PM
AccordEX1991
Mar 11, 2007 01:16 PM
jerbear!
May 9, 2005 11:00 AM
ramz7887
13
Oct 1, 2003 07:27 AM
