P/S and Clutch fluid
Old Jun 4, 2004 | 07:39 AM
AutoXer's Avatar
Default P/S and Clutch fluid
My EJ8 has 92K on it. I did the maintenance, cleaned the K&N, and did a valve lash adjust. My question is, why is there nowhere in the Helms or owners manual on a time period / milage for changing the P/S or clutch fluid?
Should this be done? I know on my other cars, it was recommended to change the P/S fluid, and I've never had a hydro tranny before, so I'm not sure about that at all. How would I go about changing the fluids, is it in the Helms somewhere?
Also, I had the Honda dealer do my timing belt service because I didn't have a place or the time to do it myself. Do the dealers change out the water pump and tensioner with the timing belt service? I know I paid enough for it, but didn't ask them about it when I picked up the car.
Thanks in advance!
Old Jun 4, 2004 | 07:45 AM
tilt's Avatar
Default Re: P/S and Clutch fluid (EX_AutoXer)
i change my clutch fluid ~15k or every year. and you prob should do it more often if you push it hard a lot.
no idea on ps fluid
Old Jun 4, 2004 | 07:48 AM
AutoXer's Avatar
Default Re: P/S and Clutch fluid (tilt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tilt &raquo;</TD></TR><TR><TD CLASS="quote">i change my clutch fluid ~15k or every year. and you prob should do it more often if you push it hard a lot.
no idea on ps fluid</TD></TR></TABLE>
How do you go about changing it? All my other cars were cable, so I have no experience at all with hydro clutch systems.
Old Jun 4, 2004 | 08:01 AM
tilt's Avatar
there is a slave cylinder attached to the front of the tranny. use a 8mm wrench and bleed the nipple on it. it's just like bleeding brakes.
Old Jun 4, 2004 | 08:24 AM
nonsense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EX_AutoXer &raquo;</TD></TR><TR><TD CLASS="quote">How do you go about changing it? All my other cars were cable, so I have no experience at all with hydro clutch systems.</TD></TR></TABLE>
read the section "Bleeding the clutch hydraulic system" just make sure that the clutch fluid never runs out in the clutch master cylinder. When you see clean fluid in the hose that you attached to the bleeder you're done.
http://www.fastlineperformance...e.htm
Old Jun 4, 2004 | 08:36 AM
AutoXer's Avatar
Default Re: P/S and Clutch fluid (nonsense)
Sweet, thanks for the great info guys!
I'll do it this weekend.
Now, about the P/S... I was thinking about just unhooking the lines from the reservoir, draining and refilling (like you'd do if you were replacing the pump)?
masterofphones
May 12, 2017 03:55 PM
PatrickGSR94
Jan 13, 2007 03:00 PM
RaVAGE00
May 17, 2003 11:36 AM
AndyD
Oct 3, 2002 09:05 AM
VTECorona
Aug 31, 2002 10:14 PM
