Cruise control in del sol not working?
Old Jun 4, 2004 | 01:07 AM
speshuled619's Avatar
Default Cruise control in del sol not working?
The cruise control in my car went out recently and cant figure out what happened. I checked all the fuses down below and are fine. I checked the switch to see if i was constant power with the key in and the key out. Im getting power from one wire behind the switch but thats all, even with the switch turned on and off. I checked for power at the cruise control box in the engine bay. Ive found that im not getn any kind of power from the harness hooked up to the box.
What can be wrong? Where is the relay for the cruise control? Id like to check that out. Also is there anything else that i can check to troubleshoot?
Old Jun 4, 2004 | 01:25 AM
eg6sir-s's Avatar
Default Re: Cruise control in del sol not working? (speshuled619)
there might be something wrong with the box internally...let me know if it is.
Old Jun 4, 2004 | 05:33 AM
93CivicSI's Avatar
Could possibly be your cable reel assembly - that is what carries the electrical signal from your buttons in the steering wheel.
Old Jun 5, 2004 | 09:43 AM
Default Re: Cruise control in del sol not working? (eg6si)
How would i know that the box itself is broken?
Old Jun 5, 2004 | 09:44 AM
Default Re: Cruise control in del sol not working? (93CivicSI)
And how can i trouble shoot the cable reel assembly?
DelSolSi1995
May 1, 2014 06:53 PM
delsolguy32
Jun 6, 2011 09:03 PM
mac_24_seven
Aug 31, 2009 09:15 AM
Juan_Mitosis
Jun 19, 2008 11:13 PM
Dezmon
Mar 9, 2007 06:38 AM
